Need help by tonight, engine problems continue
  • Thread starter Thread starter streetstang67
  • Start date Start date Jun 22, 2005
streetstang67
573
Lexington, SC
Jun 22, 2005
  • Jun 22, 2005
I'll be taking my car to the shop in the morning to get the new A/C charged up. Also, any misc. problems that I don't/can't fix will be up to the 'experienced' mechanics. No really, they seem to know what their doing most of the time with this car 20+ years older than what they work on daily...anyway, This is the list of very agrivating problems that I will have them fix unless yal can help me
Leaks everywhere, seriously, everything leaks. Water pump, oil pan, rear of intake, transmission, and rear end seal (not gasket, the hard-to-fix seal).
Aside from the leaks, I have to get my timing, carb, and valves all working together. I keep adjusting my valves, very cautious b/c I'm afraid I'll overtighten them and screw something up...never-the-less, some are still knocking. I guess my harmonic balancer is just weird, b/c I set initial timing at 12* and the car wouldn't start, just backfire. After twisting the distributor clockwise, I got it to start. Once it was going, I twisted the dist. back and forth searching for the best running position...which is pretty much where I moved it to get the engine started. Now the carb is just crazy, accelrator pump spring, mixture screws, idle, secondarys, etc...need to be adjusted.
Sorry this is getting so long, but I'm trying to save myself some money and earn some know-how for this kind of thing.
Thanks
G
grego37
576
Fresno CA
Jun 22, 2005
  • Jun 22, 2005
did you ever find a timing light to use to varify your timing?
M
my66coupe
1,134
Arizona fountain hills
Jun 22, 2005
  • Jun 22, 2005
Your timing may be set at 12* on your harmonic balancer, but your balancer may be old, and like most old balancers, the Timing marks slip. A dead give away of a crappy needed to be replaced balancer are cranks in the rubber ring. Most of the leaks you described are pretty easy to fix. Are you using a cork gasket in the rear intake? If so, I would remove it, and replace it with silicon. Is the water pump, gasket + silicon? With the transmission, your going to need to verify where its leaking. The output shaft seal is easy as is the pan, If it is leaking from the bellhousing, then you have some trouble. A rear end seal isnt that hard to replace if you have the tools, An impact wrench to remove the yoke, and your seal is visible from there. Carbs can be hell to adjust sometimes, but the best way to tune would be to find a good baseline and start from there. Most manufacturers have manuals that will start you off at a good baseline and tell you how to tune from there. Poorly adjusted valves (non adjustable valves too can cause problems if they are tightened down wrong) can cause back fires as you described. "Cautious" valve adjusting is only a big time frustration......you sound like youve done it multiple times, why dont you do it right and forget about it? I myself know how hard it is on your back to adjust valves 1000000 times. Start with 1 cylinder at a time, rotate the engine by hand. When the exhaust valve goes down, the intake should be fully up. at this point you want to tighten until you cant turn the pushrod between your finger tips. Once this is accomplished you tighten the nut another 1/2 to 3/4 turn. For the exhaust valve, watch the intake go down.....and repeat the rest. If you dont know which is the intake and which is the exhaust, look at which one leads to exhaust manifold, thats exhaust. Make sure you do your timing with a timing light, a vacumm guage gives a pretty good feel for a stock cam, but with after market, they are wayy off.
good luck man
Mike
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
Hammer shifter problems
  • 387lx
  • Apr 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 11, 2026
General karthief
