need help, car wont start.
mob
the guy who hits on his mom
Oct 3, 2003
2,566
136
104
Dallas, TX
Hey guys, It was so cold outside today, but the car was running fine from 9am to around 2pm, Went to start the car at around 2:45 to go to work and it wouldnt start. I turned the ignition on and there was power. But when I went past that its like the car just dies, the beeping slows to a stop and theres no power. Tried jumping it and wouldnt start. Checked some of the main grounds and their all fine. What else could this be? First time I try to turn it over itll click once then die, after that it dosent click, unless I leave it for a few minutes, then itll click once again but just die. Fuel pump primes. help please.
No Crank checklist for 5.0 Mustangs
Since some of the tests will bypass the safety interlocks, make sure that the car is in neutral and the parking brake is set. Becoming a pancake isn’t part of the repair process…
Check battery, terminal connections, ground, starter relay switch (also known as solenoid) and starter in that order. The clamp on with 2 bolts battery terminal ends are a know problem causer.
A voltmeter is handy if you are familiar with how to use it to find bad connections. Measure the voltage drop across a connection while trying to start the car: more than .5 volts across a connection indicates a problem.
See http://www.fluke.com/application_notes/automotive/circuit.asp?AGID=1&SID=103 for help for help troubleshooting voltage drops across grounds.
1.) Will the car start if it is jumped? Then clean battery terminals and check battery.
2.) Check the battery to engine block ground, and the ground behind the engine to the firewall.
3.) Jump the big terminals on the starter relay next to the battery with a screwdriver - watch out for the sparks! If the engine cranks, the starter and power wiring is good. The starter relay is also known as a starter solenoid.
4.) Then pull the small push on connector (small red/blue wire) off the starter solenoid (Looks like it is stuck on a screw). Then jump between the screw and the terminal that is connected to the battery. If it starts, the relay is good and your problem is in the rest of the circuit.
5.) Remember to check the ignition switch, neutral safety switch on auto trans and the clutch safety switch on manual trans cars. If they are good, then you have wiring problems.
Typical start circuit...
attachment.php
See http://www.autozone.com/images/cds/gif/large/0900823d80195963.gif for 88-90 year cars
See http://www.autozone.com/images/cds/gif/large/0900823d80195964.gif for 91-93 year cars.
See http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-95 model cars.
6.) The starter may be hung, loosen up the bolts that hold it on, and give it a good whack with a big hammer. Tighten up the bolts and try again.
7.) Pull the starter and take it to Autozone or Pep Boys and have them test it. Starter fails test, then replace it. If you got this far, the starter is probably bad.
my guess is the battery its to cold for it. whats the cold cranking rating? Had to replace mine because when it was under 30* it wouldn't start, replaced it with a diehard battery and it starts no matter what now (even if you leave the parking lights on over night *opps*.
check what the battery is putting out with...if its still 12V or not.
Unfortunatly the car is at my friends house. Went to go try again and I think the battery is dead or something. Today was probably the coldest day of winter yet here. I tried jumping the relay but touching the two big terminals, it gave out a tiny tiny spark, and clicked once but nothing after that, I also jumped the small terminal and the battery terminal and it clicked and sparked alittle. When I put the key in it beeps really slow and eventually dies. When I try to turn it over it dies still.
its 11* here right now in ohio.....im gonna have to let my stang warm up in the morning..i hate the cold....mod, try charging the battery overnight or just go pick up a nice duralast or diehard battery for around 60 bucks.
As Ryan said, you need to charge the battery up or jump it before you can run Jrichker's checklist (any testing done right now has kinda been invalid).
Good luck.
One thing to add is how old is the battery? If it is less than 4 years old then I would look to see what caused it to die. (ie. alternator, wiring, underdrive pulleys etc...) You may get a new battery and it works for a while and then dies again if there is a problem.
I always "Double Check" the grounds if there was any kind of an issue, by actually disconnecting them and making sure everything is clean and then re-securing the grounds.
I work at advanced auto parts so I might be able to cop an optima, but if not Im just going to swap out the battery cause its from there. Thanks guys, ill let you guys know if that was the problem, just gotta wait for a ride now.
You could always do some simple checks yourself. Take a voltmeter, and see what the battery reads as it sits, and what it reads when someone goes to crank the engine over. If you have 12v at rest, but a monster voltage drop when you go to start it, the battery is likely your trouble.
Dont have a voltmeter. Battery just needed to be charged.
What will you do if there was an underlying issue, like your alt going out, and it drains the battery again?
I'd atleast have the system dynamically tested at the parts store.
Good luck.
