  • 1994 - 1995 Specific Tech
NEED HELP CAR WONT START
  • Thread starter Thread starter DDSTANG94
  • Start date Start date Feb 17, 2008
DDSTANG94
465
FRASER, MICHIGAN
Feb 17, 2008
  • Feb 17, 2008
I went out to start my car and it is dead, the batery has juice, all that happens when i go to start it is the starter clicks, but wont turn it over, all the radio stations that i had programed are all rest now, does this mean it is a bad connection somewhere, of is my starter dead!!!
earleys94gt
1,223
Ashley, Ohio
Feb 17, 2008
  • Feb 17, 2008
Sounds like the starter's gone.
You can try to gently tap it with a hammer, then crank the engine to get it started.
DDSTANG94
465
FRASER, MICHIGAN
Feb 17, 2008
  • Feb 17, 2008
i tried that, but why would the radio stations re-set?
earleys94gt
1,223
Ashley, Ohio
Feb 17, 2008
  • Feb 17, 2008
Does that battery have a full 12.6 volts?
If the battery doesn't have full voltage, then the memory may have reset. That might also be part of the problem...
Hef5.0weisen
20+ Year Stangneter
Mar 5, 2004
574
NorthWest Florida
Feb 17, 2008
  • Feb 17, 2008
make sure the negative battery terminal is tight, chase the wires and have look at all the ground points, make sure they're clean and tight
good luck
DDSTANG94
465
FRASER, MICHIGAN
Feb 17, 2008
  • Feb 17, 2008
k thanks guys
DDSTANG94
465
FRASER, MICHIGAN
Feb 17, 2008
  • Feb 17, 2008
could it be the relay?
I no its not the battery i put a one in that i know was good with no results..
it has to be a bad connection right?
HISSIN50
34
129
Feb 17, 2008
  • Feb 17, 2008
I would have kept your old battery in place and used a jumper battery (less variables introduced that way).
Voltage and available current don't always correlate. In a situation like yours, I turn on the headlights and see if they dim out quickly. Then if they seem ok, I watch voltage while cranking. It should not go below about 10 volts.
Hef's advice was very solid. Check all the battery connections. By process of elimination, you can narrow it down to the starter (when they start to go, they can create an excessive draw).
I still like the bad battery or cable connection idea however (partially because you lose presets. That means your dome light and other stuff probably go out as well).
Dont forget to clean the PDC stud on the side of the underhood fusebox. It's arguably the most important and overlooked positive connection on the car. It happens to be known for corroding.
I have also had luck using a jumper cable in parallel with existing cables. I mirrora given cable, one at a time, while trying to start the car. If it magically starts, the cable you're paralleling is likely deficient.
Good luck.
Dino Dino Bambino
1,673
90
79
Cyprus
Feb 18, 2008
  • Feb 18, 2008
Exactly the same thing happened to me a few months ago and I found out that the battery cables weren't properly tightened on the terminals.
Another possibility, in you case, is that you could have a bad/loose ground connection but my money's on the first.
M
Need help please
  • Mikey62666
  • Oct 12, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 14, 2026
gkomo
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
M
2004 v8 convertible
  • Mikeycrownvicluver
  • Feb 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Feb 15, 2026
Mikeycrownvicluver
M
