Need help carb spacer?
  • Thread starter Thread starter MY 85 GT
  • Start date Start date Jul 10, 2008
MY 85 GT
1,852
208
104
New Jersey
Jul 10, 2008
  • Jul 10, 2008
Ok today my Pops came up to hear the exhaust he loved it...figures his old...lol I am going with Flows anyways The car smelled of gas he said why I said i think my carb is boiling over we took the air cleaner off and you couldnt even touch the carb thats how HOT it was.....I still have that EGR valve spacer thats metal....i think its about 1 inch in diameter.....I thought Edelbrock said to use a Phenoilc spacer <spelling...lol...I think the carb is getting way to hot ....so do you think that will help? oh yeah its an edelbrock 650 AVS CARB...
Darkwriter77
Resident Ranting Negative Nancy
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
Jul 10, 2008
  • Jul 10, 2008
1" in DIAMETER? Whoa ... that's a small inlet port! (I think you meant 1" THICK, but whatever.)
If you do go with a spacer, make sure you can put it between the EGR spacer (where a lot of heat will come from due to the exhaust gases) and the carb, rather than between the spacer and the intake. Also, make sure you'll have enough room for your air cleaner to clear the hood once you put on a spacer - just add 1" (or whatever thickness you're considering) to the current height of your air cleaner to check it. Maybe take a thick piece of clay or Play-Dough and squish it down by shutting the hood, and see how much room you have to work with up there before you go buying a spacer.
MY 85 GT
1,852
208
104
New Jersey
Jul 10, 2008
  • Jul 10, 2008
Well i forgot to mention I have the EGR valve but its disconnected all my emissions stuff is gone....I want to get rid of it because of the heat issue of a metal plate on my carb i think its making my fuel either boil over or maybe even kinda vapor lock....So i was thinking why not take that off and put a 1 inch thick Phenoilc spacer to help with heat.....Do you think that will help?
Darkwriter77
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
Jul 10, 2008
  • Jul 10, 2008
Maybe. Just don't expect any major gains from a phenolic spacer as some manufacturers will claim, and don't waste your money on any of those "power swirl" kinds of spacers - all they generally do is make a whistle noise and lighten your wallet. Also, if the spacer doesn't already come with them, be sure to pick up a set of two carb-to-manifold gaskets to throw on either side of the spacer so you don't wind up with any vacuum leaks. (I've seen people try to throw spacers on without gaskets and then scratch their heads forever trying to solve drivability/idle problems.)
Also be aware that your carb will still absorb a significant amount of heat simply from what radiates upward from your intake manifold and from general underhood ambient temperatures (exhaust heat and such). A spacer might help reduce it enough to prevent fuel boiling/vapor lock problems, but don't expect it to be cold to the touch after getting the motor up to full operating temp.
MY 85 GT
1,852
208
104
New Jersey
Jul 10, 2008
  • Jul 10, 2008
Really i thought the idea behind a Wood...Phenolic spacer was to keep the carb cooler? I mean it has to cool it down more then how hot it gets now....i mean i felt it before and WOW was it hot....i think it was hotter then my headers....lol...so i thought it well give it a try....lol.....
89streetbeast
365
horton,ks
Jul 10, 2008
  • Jul 10, 2008
Darkwriter77 said:
Also, if the spacer doesn't already come with them, be sure to pick up a set of two carb-to-manifold gaskets to throw on either side of the spacer so you don't wind up with any vacuum leaks. (I've seen people try to throw spacers on without gaskets and then scratch their heads forever trying to solve drivability/idle problems.).
been there a few times before. hear like a big exhaust leak and your like wtf
but anyway , it sounds like you're running the stock manifold, go ahead and get a 1" spacer, dont matter if its aluminum or phenolic or plastic, either or will work. only reason why some get vaporlock is cuz their timing is set too far advanced. other than that you will be fine
MY 85 GT
1,852
208
104
New Jersey
Jul 10, 2008
  • Jul 10, 2008
Thanks..I called my friend before to tell him about buying a carb spacer he said dont he has 2 lol 1 inch 4 hole Phenoilc spacer so all i need is gaskets...Now i checked my Timing today and its like 10-12 degress some were in that area...so i think thats ok....I know my Air Fuel gauge is saying RICH at idle...on the highway its still rich around 13.0 maybe hits 13.5 if i dip into the 4bbl it goes right to 12.5 so i need some tuning... Plus im going to mount a fuel pressure gauge on my cowl to check Fuel psi when idling and driving maybe i have to much PSI that doesnt help either...so much to do.........oh yeah i have the stock Manifold for now....im going to be doing H/C/I soon in the next few months....
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
J
Switched to e85 on the 3v and now it won't run right.
  • jcowdough
  • Aug 24, 2025
2005 - 2014 S-197 Mustang -General/Talk- Aug 24, 2025
