Need help fast electric fan issues
Shirley
112
Phoenix, AZ
OK. 2 Days ago my electric fan stopped working.:notnice: The 30 Amp relay that I was using was fried, I checked the fan by hooking it up straight to the battery and it works fine. For the life of me, I cannot find a store that sells this relay. I've been to autozone,checkers,ace hardware, stereo shops, and still nothing. The fan wiring instructions say that if I dont want to use a relay I can wire the high speed wire (i live in phoenix, so the fan needs to be on high) to a wire with a 30 amp fuse that comes on when the ignition is turned on. I do not have a chiltons, so does anybody know exactly which wire/wires I can use to accomplish this, and where it is located. I know i should get a dss controller, but i gots no money. I just need the fan to work reliably for me to go to school and work.
Any help is much appreciated.
thanks
Mine is hooked up to a temp sensor (advance auto $20) then to a relay (advance $3 or $4) then to a fusible link... and it's hooked to the ignition switch.
Hook it to the white with brown stripe (or red stripe not sure) wire in the ignition switch... Hooking it to the fuse box is just lazy IMO.
Somebody help me on which wire... I don't have my mustang at work.
Unbolt the panels under the steering wheel. You should see a bunch of wires coming out of a harness... that's the wires you need.
I would not piggyback a 30 amp+ drawing item into any circuit.
The relay is the way to go, and you should be able to get one at the parts store, and if not there, at Radio shack, for 5 bucks or less. Absent knowing whatever relay you use now or how it is wired, ask for an SPDT relay.
Good luck.
yeah thats the one i had. its 30 amp at 12volts and 40amp at 14.4volts. Dude I have been to three seperate radioshacks and nothing. all they have are the 4 prong ones, and they ain't bosch. Maybe the stores just suck around here. I think I should get a 50-75 amp relay just to be safe. And I can't order one online, because i needed this $hit yesterday. :bang:
The 75 amp Bosch is best IMHO, but consider the cost of it vs putting that money toward a DC control unit in the future (that is how I look at it).
If you have even a stereo shop near you (that installs alarms) they will have SPDT relays (I have had to buy a relay from those places in a pinch).
Do you use terminal 87A on your 5 prong (SPDT) relay? If not, an SPST relay will work (I cant imagine that you use 87A. It would have 30 connected to it whenever the fan is not on. I cant think of any reason to use it, off hand).
Good luck with it. At least a 4 prong (SPST) should work for you (if you have to use them), for a few days till you get some decent relays.
The country boy found out that you can use two common 30 amp auto relays in parallel to feed a fan that seems to draw more than on relay will handle.
Had to do this on my 2.3 l four Mustang. It's worked for nearly a year. A while back the fan died, so I think it was drawing too much current anyway.
BlueHatch92 said:
I got an adjustable relay at Oreilly's, had all the wiring, fuse, think it cost about 25 bucks.
For the sake of clarity (since we assume you posted this to help out future searchers with similar problems), I think you purchased an adjustable controller (with a rheostat to set the fan on/off threshold). Adjustable relays are far less common. :)
