Need help fast guys!
Ok so i started installing my mongoose kit today. Fuel pump went slow, but i got it done. Then i get to the injectors and run into a problem that I don't even know how to get out of.
I started taking off the back bolt on the drivers side fuel rail and it was coming out at a bad angle. Then all of a sudden it would just turn and not come out. I can see that the brass piece inside which has the threads is also spinning.
My guess is that some jacka$$ had changed the injectors at some point and used air-tools and forced the bolt it. The injectors look like they had newer o-rings so obviously the fuel rails have been off at some point. Now i can't get the bolt back on or off and the rail won't seat on the injectors. The minute the acc is on, fuel comes pouring out.
I'm beyond pissed right now. I just spent all this money and set aside time to finally get the blower on and now this. The only solution i can think of is to buy a new intake and swap it, something i really don't want to do
Does anyone have any other ideas? I'm open to all suggestions.
That might work, but i don't think you guys really understand the issue.
The screw threads into a brass piece that is in the plastic intake. The problem now is that the brass piece itself is spinning with the screw.
I don't think there is anyway to cut out the screw, and rethreading the brass wouldn't work since i would never be able to tighten it. Looks like i get to drop money on a used intake and swap that next weekend. Anyone have a good write-up for it?
