Need help FAST!!
Ok, if you returned it to stock and it runs fine then don't worry about that link. It probably isn't the issue. Your CAI shouldn't make your PCM too unhappy without the tune. It may not hurt it at all. You just never know. The car just isn't optimized for your CAI. Did you try several times with the tune? I know I loaded mine one day and it got all messed up and took me like 3 tries to get it straightened out.
Brenspeed made the tunes for me. I called him first thing today and he said it was either a bad file, or my throttle body was dirty inside. I looked in it and it was pretty nasty. I cleaned it real good and it runs fine with the tune now. But I was dissapointed after test driving it. I really didnt notice a whole heck of alot more power like i thought I would. Dave at brenspeed re-emailed me the tune for me to try. I may try that after while.
Well, Its acting up again. I installed the tune yesterday evening. I took it out and ripped on it it pretty had and drove it around a while and it never ran bad or through any codes. I parked it, and then ran into town to eat and about 3 miles down the road the check engine light came on and said to check bank 1 and 2 o2sensors. I cleared the car and it set long enough to cool completely down. When I went to restart it it started then died. The it started but was missing b/c it was running waaay to rich. I had to return it back to stock just to make it home.
wow meng......sorry to hear the bulls*t you're going thru. I'm sure it'll get sorted, but you, like me would want to put on the intake, load the tune, and pull instant wood - I'll try to send sum good thoughts ur way!!
Clean the MAF with spray contact cleaner or MAF cleaner. You want to shoot it up inside the small holes and make sure to try and get the inside clean. It's a good idea to clean them every 25k miles or so. Just handle it carefully. You probably have a bad tune though.
I think I may have figured out my problem. I told dave at brenspeed I had a c&l street racer tune. He told me there was no such thing, which is correct. So, being as I have a plastic inlet tube I figured it was a racer. Long story short the guy I bought the cai from said it was a street racer b/c it has the racer inlet pipe, and street 85mm MAF housing. I bet thats why my tune wont work with it. I notified brenspeed, so hopfully they can get me fixed up.
