need help. i think my engine isnt getting enough fuel.
ricehatter
at random times my car will drop power like it stoped getting fuel only for a second of 2 then picks right back up. i replaced fuel filter. new injectors, cleaned fuel system. i can nto find the fuel pump relay to check/replace it. and the fuel pump is only about 2 months old. can anyone give me a hand on where to find my fuel pump relay or any other reason why my engine would randomly drop power for 1-2 seconds then pick back up. it started doing this about a week ago for no reason
1986 mustang LX foxbody convertible 5.0L FI T5 5 speed manual, cold air intake 42lbs/h injectors performance computer/ecu, freion electric cooling fans 4.11 gears. performance tuneing computer built in ( i.e like in the fast and furious movies )
Dumping The computer diagnostic codes on 86-95 Mustangs
Revised 19-May-2009 to update drawing for dumping the codes on 86-88 Mustangs with no check engine light.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
Performace tuning computer ( like in fast in furious)? What the hell does that even mean? Sounds like your fishing for comments,so I'll bite, that's the stupidest thing I've ever heard! You have ODB-1 so unless your running quarterhorse, megasquirt, or tweecer you are lying, btw, you have NOTHING to tune. Also I think you should run 500# inj. So you get enough fuel
