  • SN95 4.6L Mustang Tech
Need help installing Pedals??
  • Thread starter Thread starter mustangmike23
  • Start date Start date Jun 30, 2004
mustangmike23
69
NJ
Jun 30, 2004
  • Jun 30, 2004
Hey bros I just got my set of Ford Racing Bullitt Pedals today and have no clue on how to put them on. I tried everything and I especially do not know how to replace the accelerator. Anyone help me out? Thanks
mustangmike23
69
NJ
Jun 30, 2004
  • Jun 30, 2004
the rubber is way too tight to get around the metal. I just cant get it around all the way. Plus i have absolutely no clue on how to change the accelerator.
O
oprude
35
Orange Park, FL
Jun 30, 2004
  • Jun 30, 2004
Run hot water over the pedals for about 30 sec, this will help with the install of the pedals, I also used a little screw driver from the back of the pedal, for the gas pedal I think there is one bolt at the top of the pedal remove it and it makes it easier to remove the little rod that holds the pedal on. Good luck it takes a little work.
SonicBlue2v03GT
648
You know its a Fact...San Diego is the greatest ci
Jun 30, 2004
  • Jun 30, 2004
I have read people talk about using soap and water...soap and hot water...heating the things up with a hair dryer...sticking a corner on then using a small flathead screwdriver to help ease them on....mashing the damn thing with your foot in a clockwise motion..Their is a pin on the acceletor pedal that you have to poke outta there, some people go to Home Depot and get a replacement bolt and washer, because its apparently about impossible to get that sucker back in there.
I am in the process of looking into getting these. These are things I have read from doing a search. There is alot of helpful info. And plenty of people say its one of the toughest mods they have done, but they all like the look. Good luck man
F
flipnsac
159
Northern CA
Jun 30, 2004
  • Jun 30, 2004
Look in here:
http://www.classicdesignconcepts.com/tech_center/bullitt_pedal_install.html
You may need to use a mirror to see under the dashboard to get to the gas pedal cable and you have to become a contortionist to work on it.
twogts4us
4,188
12
79
Dunedin, FL
Jun 30, 2004
  • Jun 30, 2004
Yep, use a small mirror, a light, some wd-40 and a couple flat blade screw drivers. For the gas pedal, it's tricky. The pin needs to be removed. We did it on both GTs, but it wasn't easy...
mustangmike23
69
NJ
Jul 1, 2004
  • Jul 1, 2004
how can i remove the pin? I tried pushing it, i tried using a hammer, i am clueless!
stallion98gt
1,802
Los Angeles, CA
Jul 1, 2004
  • Jul 1, 2004
good article there:
http://www.corral.net/Tech/Interior/BullittPedals/BullittPedals
I used their write up when installing mine
Blue Mach
141
Celina Texas
Jul 1, 2004
  • Jul 1, 2004
stallion98gt said:
good article there:
I used this one too....
mustangmike23
69
NJ
Jul 1, 2004
#10
  • Jul 1, 2004
  • #10
sweet thanks guys
twogts4us
4,188
12
79
Dunedin, FL
Jul 1, 2004
#11
  • Jul 1, 2004
  • #11
Damn, wish I had these instructions before we did both our GTs. We went into it blind...I 'let' my wife install 'em on her GT. She had 'em on quicker than I did. Still it was a bear for both of us. And we didn't take the gas pedal off but somehow got the pin in and out. It was not easy, but the results are soooo cool.
WTB Wanted - Foxbody clutch pedal
  • TTSaleen
  • Aug 4, 2026
  • Want to Buy
Want to Buy Aug 6, 2026
General karthief
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
Fox Valve Spring Kit PAC-1219X. Help finding needed additional parts.
  • 93gtmustang
  • Jul 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 31, 2026
93gtmustang
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
