Need help on 5.0 conversion.....
  • Thread starter Thread starter 22coupe_grl302
  • Start date Start date Oct 12, 2007
22coupe_grl302
Kingsbury, TX
Oct 12, 2007
  • Oct 12, 2007
I'm having trouble with my 2.3/5.0 conversion on my coupe. Got any hints?
PUNISHER RACING
1,124
FORD CITY, PA.
Oct 12, 2007
  • Oct 12, 2007
What are you having trouble with? The k-member is the same so you will need 5.0 motor mounts to set it in there, you will also need to chang trans. crossover if it was automatic. Is it going to be efi or carb? Let me know.
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Oct 12, 2007
  • Oct 12, 2007
I did this to mine...I had a donor car that made it easy...a lot of work but it is straight forward. You can use your stock dash and body harness. Get the harness from the computer to the engine, the injector harness....you will also need the headlight harness. The alternator plugs are part of it and they are on the drivers side on the 4cyl and the passenger side on the 5.0L.
What year are the two cars...if the gap is too large, I think the fuel pump relays are in different locations.
9
93green_gt
20
  • Oct 12, 2007
I am doing a conversion as well, so th K members are the same. ours is going to be carbed and we do have a donor both 90's. So I am assuming I do not need a EFI harness because it is going to be carbed?
22coupe_grl302
Kingsbury, TX
Oct 12, 2007
  • Oct 12, 2007
I'm having trouble with some of the plugs not matching each other. I'm doing all this myself. No man has helped me. It's been a bitch. I took a '90 GT and put the motor tranny driveshaft and engine harness into a '92 4cyl notch. I hope everything works. It's been pretty overwhelming for me. Go to www.myspace.com/hotassgirlinamustang.com and go to my pics and there is a pic of the notch on it.
bill302
2,131
alabama,gadsden
Oct 12, 2007
  • Oct 12, 2007
tried to view your pics. but you are set to private so i sent you a friends request..
PUNISHER RACING
1,124
FORD CITY, PA.
Oct 12, 2007
  • Oct 12, 2007
you will have to use the 5.0 computer and harness and the plugs under the battery tray will have to be switched for the alt. or you can lenghten your alt. wires by soldering in sections of wire all of the lighting wires will remain the same are you using a mass air harness(sorry about the punctuation thats how i roll)
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 12, 2007
  • Oct 12, 2007
The 90 model EFI/engine main harness is an odd duck. It is not compatible with other model Mustangs. That means your 92 harness is going to have some connections that are on the wrong place. The 92 EFI/engine main harness may be compatible with a 90 model Mustang with some interesting rework.
There are two plugs on the 90 model body main harness that do not mate up with any of the plugs on the other year EFI/Engine main wiring harnesses. Unfortunately I do not have any information as to what the two odd plugs do. I suspect that they may be for the air bag sensors.
At the top of the 5.0 Tech forum is the sticky "Useful Technical Thread" index. In it are tech writeups on a number of things like the 2.3 to 5.0 conversion.
AutoZone wiring diagrams
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model Mustangs
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model Mustangs
http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model Mustangs
K
Digital Tuning Going heads/cam/intake. Do I need a tune?
  • karhoot
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 14, 2026
karhoot
K
Electrical 1985 mustang gt Led conversion trouble
  • 1985fox
  • Jan 5, 2026
Fox 5.0 Mustang Tech Jan 15, 2026
1985fox
G
Engine ECU Question
  • GeorgeE
  • Oct 12, 2026
Fox 5.0 Mustang Tech Oct 19, 2026
JD1964
G
1980 Cobra
  • Gasmang
  • Oct 4, 2026
  • The Welcome Wagon
The Welcome Wagon Oct 7, 2026
AeroCoupe
Electrical Help me find a missing connection
  • Xavierg208
  • Feb 15, 2026
Fox 5.0 Mustang Tech Feb 17, 2026
Mcmahst
