ok heres my problem, after my car gets warmed up it runs fine but if you shut it off and start it right back up it runs like crap sounds like its not running on all 8. if you let it sit for a few minutes it runs fine. i have a 650 speed demon on it and a crane cams ignition box and street/race dizzy. the dizzy has vacuum advance on it. i took it off because the the car was stumbling off idle and seemed bogged down. it runs better now with it off. base timing is set at 14 degrees. got spark. It just started doing it after i turned the vacuum advance off. IM at a loss at this point and getting pissed off. if you guys have any ideas let me know. Or look for it in the classifed section soon if i cant get it fixed.
Thanks, Dan
Thanks, Dan
