Need help! please
  • Thread starter Thread starter Nesta
  • Start date Start date Dec 31, 2004
Nesta
38
  • Dec 31, 2004
OK I'm back at it after a long break, and trying to pull the motor. I have everything disconnected exept for the drive shaft. I need to know how to disconnect it, do I just undo the u-joint at the trans or is there another way?
If the u-joint needs to be undone how do I do this . sorry for the silly questions but I'm just not sure. Any other tips would be appreciated as this is my fist motor pull .
Thanks
351LX
1,007
Regina, Saskatchewan
Dec 31, 2004
  • Dec 31, 2004
You have to undo it at the rear end and pull the entire driveshaft out as a unit.It is helpful to either put an old slip yoke back into the transmission or cover the end with a thick plastic bag as fluid will come out the back of the transmission when you tip it.
Nesta
38
  • Dec 31, 2004
It would seem akward to remove the engine/trans and drive shaft has one unit. could I remove the tailshaft housing of the trans?
66P51GT
721
Cerritos, CA
Dec 31, 2004
  • Dec 31, 2004
That is way more work. Drain the transmission and unblolt the driveshaft from the rear differential. The driveshaft easily slips out of the transmission. Cover the tail of the tranny with a plastic bag and seal it with some rubber bands. Be sure to remove the shifter linkage.
If you are pulling the engine and tranny together, use an engine leveler. These have a nut or crank on the end to change the center of balance as you move the assembly up and out of the engine compartment.
Nesta
38
  • Dec 31, 2004
ok I see the light. Thanks for the help. I'm going for it, let ya'll know how it went.
Nesta
38
  • Dec 31, 2004
Alright, got it out and on a stand . It went off without a hitch, I guess being the first time I was just a little over cautious.
Thanks again for all the help, now for some beer....got to get ready for New Years.
rbohm
6,698
550
204
tucson,az
Dec 31, 2004
  • Dec 31, 2004
good work. as for being overcautious, that is the way to attack car repair expecially when you have little experience.
T
Need help with 302 swap
  • thxmxrgx
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 24, 2026
thxmxrgx
T
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
9
1994 Mustang GT 5.0 L Convertible
  • 94ns95
  • Jun 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 19, 2026
94ns95
9
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
Sloppy steering wheel
  • cnorman31
  • Nov 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 2, 2025
Monkeybutt2000
M
