Need help quick spindle & hub ?
  • Thread starter Thread starter stang120gt
  • Start date Start date May 8, 2006
stang120gt
72
Michigan
May 8, 2006
  • May 8, 2006
Well im putting my 5lug front hubs on right now. I have the nut that goes on the out side to tighten the hub down, But i dont remeber if there were any washers or anything that goes on before or after the hub. Before the nut goes on.
Please help
Thanks
Ozz
I think I have a problem here.
3,514
66
109
Canton, MI
May 8, 2006
  • May 8, 2006
Yes, a machined spacer or a stack of washers at .330" will do the trick. It goes on before the nut and after the spindle arm.
From sn95brakes.com: "For 79-93 cars, Balljoint spacer or stack of 3 washers totaling .330" in height or press in Sn95 balljoints to the stock arms (MOOG brand)"
So you could also just get new balljoints and skip that, but it's much easier/quicker to use the spacers.
Deece
47
  • May 8, 2006
No there is no washer to go on but make sure you get a new nut with the cage on it. They are a one time use thing from what I understand. Also the torque spec is something like 250 lbs on it hope that helps
Ozz
3,514
66
109
Canton, MI
May 8, 2006
  • May 8, 2006
Disregard my previous post, I was thinking of the spindle arm.
Tonys96Cobra
professional deer "mounter"
Oct 28, 2005
29
Syracuse
May 8, 2006
  • May 8, 2006
250 lbs? Does that seem really high?
dragnazz5.0
My "0" key d0esn't w0rk, s0 I have t0 use the zer0
Nov 19, 2005
815
mooresville, nc
May 8, 2006
  • May 8, 2006
yes...that is definetly high. torque spec is something like 20 ft/lbs while turning the rotor and than loosen 1/4 turn and tighten to 12-17 in/lbs or finger tight. its something like that. but yes, there is a washer that is supposed to go on there. and get a cage and cotter pin
stang120gt
72
Michigan
May 8, 2006
  • May 8, 2006
cool thanks guys i really appericate all the help :SNSign:ers rule
A
SN95 Multifunction Madness! Need some big brain assistance from you folks
  • Awnaw
  • Oct 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 10, 2026
AeroCoupe
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
T
Fox Convertible top issues
  • TDM389
  • Feb 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 15, 2026
General karthief
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
