Need help Removing Doors!!!
I would remove the fender, then drill a small hole, like 1/8th inch, in each hinge where it mounts to the car, then take out the bolts and remove door. To install get all your bolts started, then take the drill bit you used to drill holes when you remove doors, and stick it in the holes to get the door lined right back up. hope that helps
