  • 1994 - 1995 Specific Tech
NEED HELP RIGHT NOW!
  • Thread starter Thread starter The Red Monster
  • Start date Start date Jun 2, 2006
The Red Monster
43
  • Jun 2, 2006
I just put on my new 65mm throttle body, and it has a hanging idle problem, i'll rev it up to like 1500 rpm's and it will come back down VERY slowly!!!!!! o and when i put it into drive, it hangs at like 900 rpm's when it should be at like 650-700 in gear!!!
HOW DO I FIX THIS???????????????
thnx,
Conard
Swarzkopf
973
Pittsburgh
Jun 2, 2006
  • Jun 2, 2006
Do a search for setting your idle. You probably need to mechanically set your idle.
zkillrr
97
Memphis.Tn
Jun 2, 2006
  • Jun 2, 2006
I paid $7 bucks for a restrictor plate off of ebay, it will solve all of your problems. I had the same problem i did a search on 94 95 tech and there are some real good advice, if you need info on the plate i can give it to you
Swarzkopf
973
Pittsburgh
Jun 2, 2006
  • Jun 2, 2006
I run a restrictor plate too...but it's not going to drop your idle to what it should be if it sits at 900 steadily in gear. The throttle stop is too open if that's the case, and it needs to be adjusted.
R.J.
813
Warwick, Rhode Island
Jun 2, 2006
  • Jun 2, 2006
Try this:
Begin with a cold vehicle. The idea here is to get the car to a firm cold idle with enough air bleed capacity left in the idle circuit for IAC adjustment.
The idle stop should be set first. Back out the idle stop screw, away from the bell crank arm, until about 1/2 turn past the point where it no longer makes contact (blade fully closed). Using a 0.010" feeler gauge, tighten until gauge just drags between screw and bell crank arm. Remove feeler gauge. Tighten screw exactly 1 1/2 turns. If the screw is very loose, put a drop of loc-tite or silicone on it, so it doesn't work out of adjustment.
Now remove the connector to the Idle Air Controller (IAC) just on the other side of the throttle body. Start the car and allow vehicle to warm for 2 minutes. Give a small "blip" to let it settle. If it is having a hard time staying running you may have to get an assistant until you can get to the front of the car. Now open or close the air bleed screw (CCW opens) next to the IAC until the car idles at 575 to 600 rpm. For guys with aftermarket cams and an EEC tuner, you might want to idle a bit more briskly, say 650 to 675.
Obviously, this rpm range is by what the car and driver wants...IE, no set idle speed, whatever works for YOU.
Turn off the car. Now count the number of turns clockwise to close on the idle air bleed screw. If it falls between 1/2 and 2, it's okay, now reverse it out the same number of turns. Log the number somewhere in case you need it for the future. Reconnect the IAC. You are done.
If the air bleed screw is above 2 turns, it's a good idea to tighten the idle stop screw another 1/2 turn, and then repeat the idle setting. If it is below 1/2 turn, then loosen the idle stop screw by 1/4 to 1/2 a turn, and repeat the idle setting. Be sure to put another drop of silicone RTV on the stop screw if it was disturbed. Reconnect the IAC. You are done.
Swarzkopf
973
Pittsburgh
Jun 2, 2006
  • Jun 2, 2006
^Exactly!
zkillrr
97
Memphis.Tn
Jun 2, 2006
  • Jun 2, 2006
RJ is the one who helped me with my car, if you follow those steps he gave you; you can't go wrong!
Guero
2,148
Jun 2, 2006
  • Jun 2, 2006
worked great for me, plus i got the plate on.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Jun 2, 2006
  • Jun 2, 2006
thnx,
Conard
I love the title of this thread....an extremely urgent issue!!!!!!
Guero
2,148
Jun 2, 2006
#10
  • Jun 2, 2006
  • #10
it looked like he was tranded in Africa, and he broke down and all the skinnies were taking his car apart lol!!!!!!!!!! WTF did i just say?????????? lol
HISSIN50
34
129
Jun 2, 2006
#11
  • Jun 2, 2006
  • #11
Another one for the ages from Guero.
Guero
2,148
Jun 2, 2006
#12
  • Jun 2, 2006
  • #12
i like you to hissin!!!!!!lol
chefster
426
michigan
Jun 2, 2006
#13
  • Jun 2, 2006
  • #13
ya and after all that,disconnect your battery cables and touch them together, then proceed in the computer rerogram sequence.
The Red Monster
43
#14
  • Jun 3, 2006
  • #14
ok, guys its fixed, thamks for the help lol
runs great now!!!!!!!
R.J.
813
Jun 3, 2006
#15
  • Jun 3, 2006
  • #15
Glad we could help
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Jun 3, 2006
#16
  • Jun 3, 2006
  • #16
the skinnies.......
too funny man....
J
i need help
  • JK.
  • Oct 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
JD1964
G
Help! 93 Mustang 2.3L A4LD dies at idle
  • goofyfoot53
  • Nov 17, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 17, 2025
goofyfoot53
G
T
Engine Need help figuring out misfire and backfire
  • trystancounts
  • Sep 25, 2025
Fox 5.0 Mustang Tech Sep 26, 2025
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
R
94’ SN95 - Intermittent lope & bogging at moderate rpm
  • Red5.0ho
  • Nov 2, 2025
1994 - 1995 Specific Tech Nov 3, 2025
General karthief
