Rickki is the local guy with the meter & injectors willing to seperatate the meter? I already commited to this one guy for the injectors.
Let me know....thanks!
MSTANG said:Ok here's what I found I did KOER & KOEO scans a balance test & checked the meter voltages & ohms.
Codes were:
91 - Right EGO always lean.
67 - neutral drive switch has faults.
Balance test came back clean per the EEC.
On the MAF here's what I got...
Pin A - 15.69v
Pin B - meter was on the 20k spot
ohms to chassis = .7
ohms to engine = .11
ohms to battery = .16
Pin C - .11v
Pin D - 1.30v
All these mesurements were at idle.
I checked for vacumme leaks & I couldn't find anything so I'm assuming I have a weak/bad inj or possibly a bad O2??
So what does that tell us?
TIA everyone
mike
No disrespect at all intended, but do you have those #'s backwards?MSTANG said:14.38 engine off...
13.6 engine running
jrichker said:The MAF sensor output voltages should be measured between pins C & D. I got the impression you measured them to ground, which is not the best way to do it.
jrichker said:Also resistance checks must be done with the power off. Doing them with the power on gives false readings.
This I did, whether not correctly or not I don't know.(sorry) Should I be measuring this to ground on the harness or will the chassis or engine suffice?jrichker said:Measure the MAF output at pins C & D on the MAF connector (dark blue/orange and tan/light blue) or at pins 50 & 9 on the computer.
At idle = approximately .6 volt
..jrichker said:Check the resistance of the MAF signal wiring. Pin D on the MAF and pin 50 on the computer (dark blue/orange wire) should be less than 2 ohms. Pin C on the MAF and pin 9 on the computer (tan/light blue wire) should be less than 2 ohms.
There should be a minimum of 10K ohms between either pin C or D on the MAF and ground.
i might try carefully try to crimp the return line (or a segment of the return line where crimping can carefully be done) to narrow down the bleed-off source. seems it would either be the pump (and/or its check valve) or the regulator. the above-test can help with that (im sure you already knew this, but i thought i would toss it out).MSTANG said:Bump...
I did a little more tinkering and found out that the rail will not hold FP if the key is cycled. If you key it & peak at the gauge & it's already at zero. The Fuel pump is priming so that's not the issue.
Cranking compression is 145psi (2 psi variance) on all cyclinders & it's pulluing 15" of vac at idle.
HISSIN50 said:i might try carefully try to crimp the return line (or a segment of the return line where crimping can carefully be done) to narrow down the bleed-off source. seems it would either be the pump (and/or its check valve) or the regulator. the above-test can help with that (im sure you already knew this, but i thought i would toss it out).good luck.
MSTANG said:Yep that means I'm lean ... just how lean who knows...
When it go really cold earlier this week I swear it was detonating ... sounded like someone smacked the block with a 20 pound sledge... so I bumped the FP & it stopped. now I'm sitting at 50psi with vac.
Rickki if I could make back what I have into it it would have been chared stang already!
