Need help tracking down a noise...
  • Thread starter Thread starter 97TomGT
  • Start date Start date Jul 20, 2010
9
97TomGT
1,147
Virginia Beach, VA
Jul 20, 2010
  • Jul 20, 2010
Hey guys....it's been a few years since I posted. I got out of mustangs for a while but bought a 06 GT a few months back. The car came with a Hurst short throw shifter and I got a little frustrated with the notchiness so I swapped it out for an MGW.
When I swapped out the shifter I noticed a constant thump that seems to be in sync with the engine/exhaust. It can also be felt through the e-brake. I reinstalled the shifter twice and finally put the Hurst back in. The noise/vibration is still there with the Hurst, just not nearly as pronounced, which is probably why I never noticed it before.
There is obviously something going on that shouldnt be since I have never heard of anyone else having a similar issue. I have checked the shifter install and been under the car looking for anything that may be out of place. The only thing I noticed was that an exhaust hanger was cut when the previous owner had an FRPP X pipe installed. But I dont know why if that was the issue that I would hear it more with the MGW shifter installed.
Does anyone have any advice on what this could be and how to correct it? I could just leave the Hurst shifter on and try to ignore it, but I feel like there is an issue that needs to be corrected and I don't want to deal with the notchiness of the Hurst anymore. Any help is appreciated since I am at a loss on where to even start.
Tom
Chewyz_me
24
Jacksonville, FL
Jul 20, 2010
  • Jul 20, 2010
i had a similar problem on my old beater car. the exhaust pipe came loost and would rattle/thump under the car and u could hear it/feel it the most on the E-brake.
i would highly expect that it may be the same issue since you also stated you have a cut exhaust hanger
T
trophyyride
  • Jul 27, 2010
Hi Chewyz_me, I also have the same problem. But I can't find the appropriate solution. Pm me if you already know. Thank you in advance
SpartaPerformance
2,517
61
89
Long Island NY
Jul 27, 2010
  • Jul 27, 2010
I would start with that exhaust hanger replace/fix problem 1st. The reason you feel it more with the MGW is because the shifter is designed to absorb all its vibrations in the base, that's why George himself states that you should never rest your hand on the shifter when driving because it will crush that bushing.
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
