  • SN95 4.6L Mustang Tech
NEED HELP W/ BRAKE PADS!
  • Thread starter Thread starter UofMfooTbaLL24
  • Start date Start date Apr 25, 2004
UofMfooTbaLL24
62
Michigan
Apr 25, 2004
  • Apr 25, 2004
Today I went to change the brake pads on my car, and i got everything off that i needed to and all, but after that i put the new pad on and i coudlnt get the unit htat squeezes the pads to fit over the new pads. My neighbor told me that a C-Clamp would work and I would be able to push the little circle thing (i guess it might be the piston) that pushes the pads on to squeeze back in so that i could slip it over. Well that thign wouldnt budge with a clamp so now i cant fit the unit in over the pads. Sorry I'm pry not using the correct terms, i dont know much about brakes, can someone help me that has done this before? Thanks!
W
Wi-Stanger
111
Wisconsin
Apr 25, 2004
  • Apr 25, 2004
Is this in the rear? You need either a needlenose pliers or much better would be the rear brake kit from autozone. You can rent it for 35 bucks and get all your money back when you return it. You can't squeeze the back pistons in, they need to be twisted with the tool. If you look, you can see 2 slots in the piston. Someone told me to adjust the parking brake also but you will need other folks input on that one.
UofMfooTbaLL24
62
Michigan
Apr 25, 2004
  • Apr 25, 2004
yeah it's for the rear, any other suggestions?
W
Wi-Stanger
111
Wisconsin
Apr 25, 2004
  • Apr 25, 2004
Just make sure you crank the piston in enough so you can slip the caliper over the pads without forcing it. Also check this out.
http://www.mustangworld.com/ourpics/fcar/brakepad1.htm
Good luck!
CHANGING BRAKE PADS
  • Scwhitten
  • Jun 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 12, 2026
nickyb
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
C
Fox Need help identifying brake setup
  • Cypher02xd
  • Apr 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
Mustang5L5
F
5 lug disc brake pad help
  • Foxrider714
  • Nov 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 17, 2025
KRUISR
9
Brakes Rear brakes feel stuck after replacing pads and rotors
  • 99stanggtvinx
  • Aug 31, 2024
SN95 4.6L Mustang Tech Sep 1, 2024
nickyb
