Need help with 89 mustang mis-fire
ncpantherfan
I have a 89 4 converted to 8 with a 88 5.0 and computer (mass air).
About 6 months ago I started to get a missfire, stumble and back fire during acceleration throught the intake after the car warms up. When cold it runs perfect.
That went on for about a week and then fuel pump went out.
Changed pump and filter, still there.
Changed coil, wires, plugs, cap, rotor, and ICM on front of dizzy, and retarded timing back to 10deg. the miss got better, but started back firing from exhaust on deceleration, so I changed the entire dizzy. Installed it, wanted to go for a test drive and the new pump went out.
I am new to computer cars and I am lost.
does anyone have any ideas?
Dumping The computer Diagnostic codes on 86-95 Mustangs
Revised 24-Apr-2009 to add warning to turn off A/C and place transmission in Neutral and dumping Engine Running codes.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 11 and not be able to dump the Engine Running codes.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
attachment.php
attachment.php
WARNING!!!
There is a single dark brown connector with a black/orange wire. It is the 12 volt power to the under the hood light. Do not jumper it to the computer test connector. If you do, you will damage the computer.
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Codes have different answers if the engine is running from the answers that it has when the engine isn't running. It helps a lot to know if you had the engine running when you ran the test.
Alternate methods:
Or for a nicer scanner see Equus - Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
