Need Help with Alternator wire
So far bout my new alternator it is 175 amp one but when I put that on I also got the upgraded wiring kit with it from the company...now that was a 4 gauge wire and that got burnt through by the connection right behind the alternator... After that i put a 2 guage wire on and it got burnt through by the connection by the fuse box. Now does anyone know what the problem could be...also the wire is burning from the inside out and is there a place where i can buy a 0 or 1 guage wire?
Thanks guys,
Dan
Bad connections = heat, which = resistance = more heat, which =.................
The best connections will be oxygen free. But you should be able to make something good yourself.
Does the cable get physically hot (disregarding engine heat) that you can tell?
You could have a local stereo shop fab up a cable for you if you like. They would have the correct crimpers (pliers are not all that great, though I have used solder and lineman's pliers with success) and cable to whip something up.
Random thoughts. Good luck.
The best way to make a connection that I've noticed (just did it with all of my positive and negative cables [battery, positive to starter, and grounds]) is to get some of the copper connectors that are meant to be crimped on, but heat them up with a propane torch, fill them with solder, and while the solder is still liquid, shove the wire in. Once it's cool, seal it off with some heat shrink tubing and you're done.
