Need help with gauge installation
  • Thread starter Thread starter frankoman87
  • Start date Start date Sep 4, 2005
F
frankoman87
27
Denver, CO
Sep 4, 2005
  • Sep 4, 2005
I almost have my tach installed but I don't know what wire to connect to my tach sensor. It says in the instructions to connect it to the negative wire. There is a red wire and green wire and I can't tell which is positive and which is negative. Any assistance would be appreciated. Thankx
GearHd6
459
Ashford, CT
Sep 4, 2005
  • Sep 4, 2005
The green is negative
HISSIN50
34
129
Sep 4, 2005
  • Sep 4, 2005
The one with green on it is the neg coil wire IIRC.
I thought the coil's connector was labeled too. If you have the car running and use a test light, one wire will show constant 12 volts, and one will pulse real quick. Use the pulsing wire.
Good luck.
F
frankoman87
27
Denver, CO
Sep 4, 2005
  • Sep 4, 2005
Thanks guys. The whole job took about 3 hours. It is sooooooo great to have a tach again. It's like a luxury now for God's sake!!!!
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
J
Fox Lost all gauge cluster function after Holley Terminator X install (solved)
  • Justin17383
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Friday at 3:09 PM
2000xp8
F
3G Alternator install question
  • fathead429
  • Oct 24, 2026
1974 - 1978 Mustang II Talk & Tech Oct 25, 2026
LILCBRA
Resolved Wiring electric fan
  • cbac89
  • Aug 29, 2026
cbac89
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
