Need help with gearing problem
  • Thread starter Thread starter ms93gt
  • Start date Start date Oct 20, 2004
M
ms93gt
239
Bayville, NJ
Oct 20, 2004
  • Oct 20, 2004
Ok I have a 93 Gt and at 65mph I am driving at 2500 rpms, Now I checked the tag on my axle cover and it says I have 3:27. I spun the tire and counted the driveshaft and it also came out to 3:27, but my car was originally an aod and I swapped it into a 5speed. I didnt change the speedo gear but I don't believe my speedo is off. What could be my problem for taching so high on the parkway, is my 5th gear real short? Do I have diff gears and maybe I miscounted the driveshaft? Or could my tps be off?
M
ms93gt
239
Bayville, NJ
Oct 21, 2004
  • Oct 21, 2004
anyone
squeeeg
1,905
Michigan
Oct 21, 2004
  • Oct 21, 2004
What transmission did you use in the swap? I wouldn't really worry about it id you sig is still going to happen about getting the 3.55's just change the speedo gear then and everything should be ok
M
ms93gt
239
Bayville, NJ
Oct 22, 2004
  • Oct 22, 2004
i put a 93 world class t5 in
T
tjm73
2,418
Rush, NY
Oct 22, 2004
  • Oct 22, 2004
What size tires do you run? ex: 225/60R15 or 275/50R15
T
tjm73
2,418
Rush, NY
Oct 22, 2004
  • Oct 22, 2004
I think your speedometer is off. 1993 AOD's had an 8 tooth output gear for the speedometer cable. Depending upon which year tranny you swapped to it could have a 7 tooth output gear. If it is a Z spec T5 it has a 7 tooth output gear.
In about 1989 (I think) the T5 changed to an 8 tooth output gear which would make your speedometer correct as it is right now. I suspect you have an '88 or earlier T5, or a FRPP T5, with a 7 tooth output gear.
M
ms93gt
239
Bayville, NJ
Oct 22, 2004
  • Oct 22, 2004
I'm running stock sized tires, 225 55's all around. The guy I bought the tranny from claimed it was a 93. I ran the tag and I believe it came out to either a 90,91, or 92, but I wasn't worried because they're all rated for 300ft lb's of tq. (I didn't want an 87-89 bc of the lower tq numbers)
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
T
Newbie looking for some info on speedo gears
  • TDM389
  • Nov 15, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 16, 2025
TDM389
T
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
