need help with headlight installation
greenman49
"I'm trying to install some projection headlights on my '94 Mustang. The instructions that came with them are a joke, no info whatsoever. I think I have everything figured out except there are two female connectors on the new wiring harness that look like this:
_______
| __ __ |
| __ __ |
|______|
The instructions for connecting them only say "to relay". I assume they mean the headlight relay, but I can't find any reference to Mustangs having a headlight relay, what it looks like or where it's located. Please help."
I seem to recall a fog light relay but not a headlight relay.
So it sounds like this is a relay you add (which makes sense since it doesnt sound like you have a plug to connect to the OEM headlight connector).
And it's just a good way to do things (I added relays on lows, highs, and fogs on the fox and it helped).
Find out what style of relay you are to use (it's probably a SPST relay, but it might have two 87 terminals - the second 87 would be where 87A normally is, in the center of the relay).
Once you have that , it should be super cake to wire up the relays.
Good luck.
