need help with heads
92 5point0
ct
i have a e303 cam and stock heads and my car wont start up and idle you have to start it then keep reving it until it warms up then it idles my friend told me that its only cause i have the stock heads and it idles rough what kind of heads should i use for fairly cheap and or wut else could be the problem
See the "Surging Idle Checklist for help with all your idle/stall problems. The first two posts contain all the updates to the fixes. At last count there were 24 possible causes and fixes] for surging idle/stall problems. I continue to update it as more people post fixes or ask questions.
Is that something that started right after you installed the cam?
My car did the exact same thing at one point. I changed the air temp sensor and the car ran great afterwards. The air temp sensor was all gumed up and shot.
Gives you a place to start, pull it out and take a quick look at it....
