Need help with hood alignment
I think the back sitting to high is a very very common problem with hoods. my 66 was like that and I have seen many classics like that. Are you sure that your hinges are closing all the way in the back and that your hood isnt hitting anything?
Does this help?
Just kidding, the old hinges always have a tendency to lift a little at the back when they get a little worn.
My original hinges are "stretched" after shutting the hood with a socket on the frame rail.:bang: Amazingly, the hood did not bend. This goes to show how weak the originals are after all of these years. Worse yet, I have heard several people here say the repros are even weaker.
A buddy of mine told me to loosen up the bolts to the fender and push up on the open hood.... while applying upward pressure on the front of the hood tighten up the fender bolts. Supposedly that worked for him on the same problem..... If it works let us know... lol
Graham
I agree with blk about pushing upward on the hood after loosening the bolts that connect the inner side of the hinges to the fenders. I was told by a body specialest to do this and after about 5 trys you should get it perfectly aligned. Also its located in the chiltons book:D.
