Need help with line lock installation
Im pretty sure our stuff is standard 1/4" brake line. Then again, I could be wrong because the fittings on each side of the car are different.
Anyway... Discount Auto has short brake lines with adapters on them. What I would do is after the proportioning valve, id remove the front brake line from the valve, and then bend the lines appropriately, and use a couple adapter lines to connect it.
