this is what the car does have,
trickflow powder colted street heat 75 mm intake upper and lower..
C/L 76mm mass air
BBK full BBK 70mm Throttle Body w/70 mm EGR Spacer...
BBK Cold Air Intake ...
BBK full length 1 3/4 CNC ported Silver Ceramic headers
24 pds injectors
Trick Flow Twisted Wedge® 185 heads that are CNC ported to 215
1.72 rollor rockers
E-303 cam
ARP bolts
C/L 76mm mass air
flexkool Aluminum Radiator
Flex-a-lite 398 fan
MSD 6AL Digital Ignition Module
msd Blaster HVC,coil
msd Distributor cap
msd 8.5 wires
NGK Performance Spark Plugs
SCT eliminator chip
Steeda Tri-Ax short throw shifter
double hook quadrant
southside lower lift bars
double adjustable upper control arms
255 i fuel pump
flo masters 2.560 pipe H
Steeda Drag Springs
BBK Camber plates
Sub Frame Connectors
wheels.. cobra 17s
tires.. 235 45 r 17s
moser axles
3.73 postive trac
5 speed Transmission
Centerforce Dual Friction Clutch & pressure plate
70-30 Lakewood Drag Struts
kyb rear shocks
m/t 26x8.5-15
