Anyone with knowledge of the MW article, and the Mach 460 headunit please advise. Does that unit put out a high level or low level signal through the data cable? I have everything wired correctly as per the diagram. I used the plastic snap connectors to tie into the wires as per this pic:
My problem is that the Signal Sense on my JL 500/1 amp is not totally working unless I crank up the volume in the car to 3/4 power, and even at that, my 10W7 is just barely moving. I know this sub should really be pumping, and I have also turned up the sensitivity on the amp, but I am cautious as to how high I go. I am not sure if I should have the input on the JL amp to High level or Low level.
Anyone with knowledge on this amp and/or the Mach 460 head unit, please advise. The stereo in the car still sounds great. The 10W7 is not up and running yet though.
Thanks in advance for any help that can be offered.
~Darren
~Darren
