Need help with my setup
Smeckel
751
Meriden, CT
I have some twisted wedge heads waiting to go on my mostly stock engine. I just took some money out of the bank and am looking to buy all the other parts to put them on. So far I just have the heads and correct hardened pushrods and am pretty sure I'll get a track heat intake.
My questions are, what size MAF should I get?
Also I was planning on getting 30# injectors so I have some room in the future, good size?
Would I be ok with a 65mm TB or should I go 70mm?
And last but not least, I know I have to get a 190lph fuel pump, but am I forgetting anything else?
Good heads bolts ---> www.arp-bolts.com
i heard that 65 and 70mm TB give about the same performance,so...
I run a 73mm maf,and a 190lph fuel pump.. if you planning blower or nitrous for the futur,go with a 255lph.
Maybe a set of 1.6 roller rockers !? To be FULL ROLLER!!! :D :D :D :D :D
Yeah I forgot to note that I was planning on a stage one trickflow so I dont have to worry about piston to valve clearance. I also already have some trickflow 1.6 roller rockers already on the head so i forgot them as well.
bock said:
what are the specs for this stage 1 trickflow cam?
From summitracing.com
Specifications:
* Advertised duration: 275 intake/279 exhaust
* Duration at .050 in. lift: 221 intake/225 exhaust
* Gross valve lift: .499 in. intake/.510 in. exhaust
* Lobe separation: 112 degrees
* RPM range: 2,000 to 5,500
