need help with power window
chrisilversvt
66
memphis,tn.
ok so here's the deal....since i bought my '95 the drivers side switch for the passenger window wouldn't roll it back up,it worked to roll it down,but i'd have to use the pass. side switch to roll it back up...
so yesterday i go to roll it up with the pass. side switch like usual,and it doesn't work anymore either...it will still roll down from both switches,but it won't roll up with either...which really sux because my window is all the way down now....so ican't really drive my car until i fix it......
is there a way to manually roll it back up until i can get it fixed?????has anyone else had a similiar problem?????do you guys think it is the motor,or a problem with the switches????i'm thinking its the motor,because i had a similiar problem with my 93 lx,and a new motor fixed it...any ideas or advice would be appreciated....
Look in the Faq Sheet sticky in here. You probably just need to replace the bushings in the motor. Mine did the same thing with 3 of the windows and after spending $10 on bushings and a saturday afternoon ripping everything apart they work mint now.
