Nope.
Does it feel like nothing is hooked to it or just does not pull far enough? Pull the door panel and see if the holes where the rod attaches is worn, sometimes you can tweek the rod but not by much.
Sorry, miss read your post, INSIDE door handle, easy peasy, one phillips head for trim around it and one for the handle itself, you will have to move it forward or backward, can't remember, there are tabs that hold one end.
Thanks everyone, I figured it out, nothing broken I had replaced some of the plastic panel tabs and it was interfering with the rod. Removed the tab it works fine.
