need help
y0rascal
767
Davie, FL
hey guys its been a long time since ive been on here anyways my fog light bulb on driver side is out and has water in it how can i change the bulb ive tried already and dunno how to take it off im not a big mechanic so any little help is appreciated thanks..... baiscally tell me how to change the bulb heh
You have to pull the 2 clips off of the light case under the hood. They come straight up and are long and thing, they have sort of an "L" shape. Then you have to pull the entire light fixture forward away from the body and you should be able to reach the bulb.
Just unscrew and replace the bulb and reverse the process to get it back in. When you push the light back into position, it will snap in and then you can put the clips back in
*Edit - Hello, I'm an idiot...you said fog light. My bad. Dunno...mine have never gone out
