  • SN95 4.6L Mustang Tech
???NEED HELP!!
  • Thread starter Thread starter Jake795
  • Start date Start date Jul 26, 2004
J
Jake795
110
  • Jul 26, 2004
OK, I can't reattach my transmission b/c the bellhousing is hitting my new headers that i installed while i had my engine out of my car. I figure i have two options: take off one header and attach tranny and reinstall header OR pull the engine back out and attach tranny with the engine out of the car and reinstall everything as a single piece. I would rather pull the engine back out b/c it looks like a ****** to take that header loose in the car. Please let me know if its even possoble to install the engine and tranny together like i'm planning.
thanks,
Jake
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Jul 26, 2004
  • Jul 26, 2004
i believe that it would be easier to take out the header and put the tranny in and then put the header back on. i belive that the only LTs out there that allow you to take the transmission out with the headers still attached are the hookers.
J
Jake795
110
  • Jul 26, 2004
at the point i'm at it would be easier to pull the whole assembly out, engine and all. My main question is if i can put the engine and transmission back in the car together?
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Jul 26, 2004
  • Jul 26, 2004
i belive you can, however you will not be able to put the headers on outside the car. i dont have a lot of experience with LTs because they are illegal, however from what ive heard that is the case. remember when your mustang was built the engine was put in from below the car.
J
Jake795
110
  • Jul 26, 2004
thanks for the info. I had forgot about them being assmbled from below. I may see if i can seperate the tranny from the bellhousing and then work the bellhousing on and reattach everything.
Jake
J
Jake795
110
  • Jul 27, 2004
Any other ideas from anyone that's installed LT's with the engine out of the car?
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
Cooling Jacket Pitting Idea's?
  • BoostedRed89gt
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Mustang5L5
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
A
Help ID - Turbo GT, SVO differences
  • aldoelmalo
  • Jun 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 2, 2026
aldoelmalo
A
T
Fox Help Request: Clutch Cable Installation on T5 Swap — I Can’t Find the Mounting Hole
  • TDM389
  • Feb 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 19, 2026
nickyb
