  • SN95 4.6L Mustang Tech
Need Help!!
  • Thread starter Thread starter BayArea02GT
  • Start date Start date Nov 20, 2004
BayArea02GT
44
Newark, CA
Nov 20, 2004
  • Nov 20, 2004
I just took out the stock shifter and I do not see any oil inside the transmission!! Is it normal? If not, then upto where do I fill it in and what type of oil should I use?
D
Darkhorse845
Banned
Nov 17, 2004
101
Las Vegas,Nevada
Nov 20, 2004
  • Nov 20, 2004
Do you have a T-45 or a T-3650 because you have a 02?
BayArea02GT
44
Newark, CA
Nov 20, 2004
  • Nov 20, 2004
I have 3650. I just talked with George from MGW and found out that I am just freaked out! lol
D
Darkhorse845
Banned
Nov 17, 2004
101
Las Vegas,Nevada
Nov 20, 2004
  • Nov 20, 2004
You should have oil in the trannsmission or you will fry it.The oil
capacitie is 2 1/2-3 qts in a T-3650.Any ATF will work but,I do
recommend Mobil One ATF though.Take off the trannys' drain plug
and make sure there is no fluid before filling or else you will overfill it.
You can pour the fluid in through the hole or through the hole in the
tranny.Good Luck!
BayArea02GT
44
Newark, CA
Nov 20, 2004
  • Nov 20, 2004
Thanks for the info!! By the way ...
MGW's Shifter =
D
Darkhorse845
Banned
Nov 17, 2004
101
Las Vegas,Nevada
Nov 21, 2004
  • Nov 21, 2004
Your Welcome enjoy your new shifter!
Need help ordering a oil cooler and filter relocation kit but don't know what I need
  • Aiden Brown
  • Aug 22, 2026
SN95 4.6L Mustang Tech Sep 14, 2026
squeak93
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
T
Digital Tuning Hello OBD2 problem
  • TNmach1
  • Sep 18, 2026
SN95 4.6L Mustang Tech Sep 18, 2026
TNmach1
T
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
