Need Help
  • Thread starter Thread starter SteedaGT9150
  • Start date Start date Apr 8, 2005
SteedaGT9150
Advanced Member
Nov 10, 2004
1,351
59
68
Maryland
Apr 8, 2005
  • Apr 8, 2005
today i started the stang but i had to push it to get it started. Does this sound like a celenoid or starter problem? thanks
notchback
1,950
St Clair Shores MI
Apr 8, 2005
  • Apr 8, 2005
next time you start it...if it doesn't....jump the selonoid first..
turn the key on and use a screwdriver to join the pos batt terminal to the one w/ the little red/blue wire on it. (right on top)
you'll get a couple sparks...but it will start the car. if not it's the starter itself...have someone turn the key like they are starting it...and rap the starter w/ a hammer..if that starts it, it's the starter for sure, but it's one of the 2
SteedaGT9150
Advanced Member
Nov 10, 2004
1,351
59
68
Maryland
Apr 8, 2005
  • Apr 8, 2005
i didnt turn the key but i touched the selonoid with a screw driver and it did spark so does that mean the selonoid is still good or is it bad?
notchback
1,950
St Clair Shores MI
Apr 8, 2005
  • Apr 8, 2005
you have to turn the key on...if the key is on and it starts at the selonoid...the selonoid is bad
they are 6 bucks i think...get 2 so you never have to deal w/ it again...i broke one only 2 weeks after i replaced the old one
SteedaGT9150
Advanced Member
Nov 10, 2004
1,351
59
68
Maryland
Apr 8, 2005
  • Apr 8, 2005
thanks i was doubting it being the selonoid because i just replaced it this fall but i guess it could have gone bad again
notchback
1,950
St Clair Shores MI
Apr 8, 2005
  • Apr 8, 2005
yup, you got the borg-warner right?
thats what everyone carries, and is also the stocker as well...but yeah i had one that stuck in "start" ... key out of the car and was still turning over....
had to discon the batt cable
2 weeks later...same parking lot...same thing....what a ******
HISSIN50
34
129
Apr 8, 2005
  • Apr 8, 2005
the starter will turn over if you jump the solenoid with the key off. the car simply wont start.
to check the solenoid: do as Notch said - jump the little trigger wire to the battery lug on the solenoid. if the car wont start, now try jumping the two big lugs on the starter solenoid. if the first test fails but this second one works, the solenoid is bad.
good luck.
SteedaGT9150
Advanced Member
Nov 10, 2004
1,351
59
68
Maryland
Apr 8, 2005
  • Apr 8, 2005
yeah its the selonoid ill go to autozone tomorrow and pick one up after my baseball scrimage thanks
HISSIN50
34
129
Apr 9, 2005
  • Apr 9, 2005
or see about getting an oem unit - might hold up better for ya. good luck.
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
M
Idle control valve
  • miser143
  • Oct 31, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 1, 2026
General karthief
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
