need help
I helped eddie take everything off and rerun the heater hose but wasn't arounf for reinstallation.
Is there anything else that would be interfereing with the manifold sitting flush on the heads besides the heater hose? Is there anything else that needs to be changed out to fit this manifold? Thanks Guys!
Josh
Check to see if you maybe pinched a wire or vacuum line under the manifold when you put it on, if so, you may be able to loosen the bolts and just pull it out, otherwise you'll have to pull the intake off again to see what's wrong.
