Need Help!!!!!!!!!!!!
  • Thread starter Thread starter zadroga
  • Start date Start date Mar 12, 2006
Z
zadroga
  • Mar 12, 2006
I just picked up an 89 Gt. The car was sitting a year, and when we finished putting it back together all it needed was a new battery and it fired right up. Two days later the car would not start. I measured the battery, and it was completely dead. So I asked my neighbor to jump it. As soon as we hooked up the jumper cables one of the wires coming off the starter relay started smoking and burnt up. If I traced the wire right, it splits into two wires, one goes to the alternator, and the other goes to the voltage regulator on the alternator. What could cause this, and what can I do to get it fixed ASAP?
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Mar 12, 2006
  • Mar 12, 2006
You have a short. You need to so a parasidic load test and dissconect different components in the suspected circuit until you find the location.
Z
zadroga
  • Mar 12, 2006
ok this is what I did. I found out that the fusibale link will blow if there is a bad ground on the battery. I put a new ground cable in, cut the fusible links out and put a normal fuse is place. Now, if jumped the car will start and run fine, but the battery will not hold a good enough charge to restart. How many amps does the alternator need to recharge the battery? I have a 15 amp fuse in there right now, but is it enough to charge the battery?
T
TheUser
1,859
Springfield, MO
Mar 12, 2006
  • Mar 12, 2006
stock alternator is 65 amps and many say it's not big enough. I don't know how well 15 amps would charge the battery, but it must not be getting more than that or it would blow the fuse. Maybe get the alternator tested? If it's bad, you can either get a rebuild kit and rebuild yourself (like $10 or something and not too hard) it or a remanufactured one is like $40-50 probably.
Electrical Ron Francis Headlight / Alternator Harness
  • dan50
  • Apr 30, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
dan50
Electrical Starter solenoid out of space?
  • 387lx
  • Jan 22, 2026
Fox 5.0 Mustang Tech Jan 23, 2026
387lx
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
M
Need help please
  • Mikey62666
  • Oct 12, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 14, 2026
gkomo
