need help
rockyracoon
874
27
49
margate NJ
My thermostat fan controller keeps blowing fuses.if I put a paper clip in the holder the fan will run but the fuse holder gets hot.the fan controller has a relay that plugs into it.The controller works and cycles the fan off and on . the fan works good when it is running and it is extremely quiet.Is there a way to check the fan with a voltmeter to see if it is drawing too much current?the way this controller is wired there is red wire going directly to the battery,there is an orange wire that is fused with a 25 amp fuse that goes to the fan,there is a black ground wire,there is a green wire that goes to the A/C switch,and a yellow wire that goes to constant 12v.I used heavy gauge wire on the red and the orange wire figuring that would minimize resistance, is that a possible problem?
You are likely right - the fan might simply overwhelm the relay (30 amp SPDT?) when it kicks on and loads up.
I think it was Mike that had a setup similar to yours. He posted what sized relay he was using but I think it was 45 or 50Amps. I'll see if I can find the post.
Current draw is what heats up, and sometimes melts wire
well I was able to check the amp draw with my battery charger.With the fan on high speed the amps initially go to about 45 and then settle out to around 30 in low speed the amps peak at around 25-30 and then level out to around 16-20.I have it wired up in low speed temporarily and the fuse is not blowing but im not sure whether low will be enough on those hot summer days.the thermo controller has a relay that plugs into it but I think that is just for the a/c.the inline fuse is on the wire going from the controller to the fan.Im thinking for longevity of the controller I should add a relay coming from the battery.
I would use a relay for each speed on any controller (other than a variable controller, obviously).
Bosch has 75 ampers that are common for this application, but $$. FFI has 50 amp Bosch relays for cheap (as well as the 75 amper if needed or desired).
Good luck.
