  • SVT Tech Forum
NEEd Help
  • Thread starter Thread starter cobra-ized
  • Start date Start date Mar 1, 2009
cobra-ized
18
Keller Texas
Mar 1, 2009
  • Mar 1, 2009
I haven't started my 98 Cobra in 7-8 months. I went to start her, she fired up just for a second, then died. She will turn over, but won't fire up. Where should I start to get her running?
P
Price1
109
Dryfork, WV
Mar 1, 2009
  • Mar 1, 2009
It is typically a fuel or a spark problem. First, I think you should try to ascertain which it is. Pull a plug, ground it to the engine, turn it over and see if you are getting spark. Then, listen to hear if the fuel pump "starts" when you turn the key to the "on" position.
I take it there is gas in the tank. 7-8 months is a long time to leave it.
Start with the basics - fuel and spark - and see where that leads you.
Good luck......
cobra-ized
18
Keller Texas
Mar 2, 2009
  • Mar 2, 2009
Thanks for the input
cobra-ized
18
Keller Texas
Mar 8, 2009
  • Mar 8, 2009
OK, checked for spark...got that...checked fuel pump fuse, inertia swith...going to get gauge to check fuel pressure at schrader valve....
2BADSTANGS
385
Colorado
Mar 8, 2009
  • Mar 8, 2009
You may try replacing the fuel filter while you're at it. It could have gunk built up after sitting.
cobra-ized
18
Keller Texas
Mar 8, 2009
  • Mar 8, 2009
No pressure at schrader valve, checked fuel pump fuse-good, going to change fuel filter next. Any way to check fuel regulator?.......These cars have changed since the 69 Mach 1
cobra-ized
18
Keller Texas
Mar 9, 2009
  • Mar 9, 2009
Pulled fuel filter, clogged. It is wise/possible to check fuel pump while car is jacked up, by running hose from exit of filter to gas can and ever so quickly turning key to see if pump is working?
cobra-ized
18
Keller Texas
Mar 19, 2009
  • Mar 19, 2009
Replaced fuel pump, fired right up............................
COBRA90GT
Mustang Master
Sep 22, 2001
6,654
HOCKEYTOWN ® , MI
Mar 21, 2009
  • Mar 21, 2009
Glad to see you fixed it. Were you able to test the original fuel pump to see if it was functioning before you replaced it? Just wondering if you tried that idea of turning the key on and letting it pump fuel to the fuel filter hoses and draining it off to a pan or whatever...
cobra-ized
18
Keller Texas
Mar 28, 2009
#10
  • Mar 28, 2009
  • #10
Yes, I tried it and nothing. I then ran pos/neg wires off battery and hooked up to wires at wiring harness, nothing. I was confident at that time it was pump. On draining the tank, took vent hose of side of tank and siphoned out gas. No spillage at all. Totall time changing pump from start to finish, 1 1/2 hours.
Hi. I'm new. 98 Cobra Bent Axle.
  • sbk93036
  • Mar 28, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 5, 2026
Mustang5L5
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
J
Help - SCT Woes
  • James banks
  • Jan 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Feb 2, 2026
squeak93
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
  • SVT Tech Forum
