  • SN95 4.6L Mustang Tech
Need hints on installing new plenum and TB
  • Thread starter Thread starter Charged 96 GT
  • Start date Start date May 12, 2004
C
Charged 96 GT
57
Upstate SC
May 12, 2004
  • May 12, 2004
Got any thing to make the swap go smoother? The new ones are suppose to be here Friday.
Go HoTO!
602
Mountaintop, PA
May 12, 2004
  • May 12, 2004
1 - Take your time
2 - Don't loose the screws.
3 - Take before photos if you are a cluts (sp?)
4 - Buy a back up TPS to have ready in case you need it. Lots of guys have problems getting them off, or they just don't work right with the new TB. You can always return it if you don't need without having to run to the store. Especially if you are doing it late at night when nothing is open.
5 - Clean your IAC. Why not? It's already out anyway.
6 - Be sure to disconect your battery before you start.
If the idle seems dicked after you have it all together, let me know and I can help. It should idle smoothly at at about the same rpms as it did before the swap.
twogts4us
4,188
12
79
Dunedin, FL
May 12, 2004
  • May 12, 2004
On my 2002, when removing the EGR valve, the rear bolt (closer to the firewall) required a 10mm (I'm pretty sure it was 10) deep socket. It seemed no other tool would work to get this one out. Make sure you have the correct socket for this one. That was the ONLY trouble I had.
2Slow96GT
22
South Carolina
May 12, 2004
  • May 12, 2004
It is a really easy swap. Shouldnt take more than half an hour.
C
Charged 96 GT
57
Upstate SC
May 12, 2004
  • May 12, 2004
Thanks for the info guys. 2Slow96GT what part of SC are you from?
02_2VStang
73
Cary, N.C.
May 12, 2004
  • May 12, 2004
yeah same thing happend to me yesterday...only trouble i had, i had to get a 10mm deep socket to remove the EGR valve. couldnt get anything else to budge it.
C
Charged 96 GT
57
Upstate SC
May 13, 2004
  • May 13, 2004
I got the 10mm socket anything else? What do you use to clean the IAC?
Go HoTO!
602
Mountaintop, PA
May 13, 2004
  • May 13, 2004
get some intake cleaner at any auto parts store. make sure it says that it is safe for TB's. Just spray it inside the IAC and let it soak for a while. Do it a couple of times and you are done.
stimmler
248
Japan
May 14, 2004
  • May 14, 2004
Here was my fix for the TPS problem....
If you are unable to get your TPS sensor off, take the old plenum (with TPS) and put it in the freezer for an hour in a bag with some WD-40 on the bolts. Then use a socket adaptor set and you should be able to break the screws loose without ruining the screws.
twogts4us
4,188
12
79
Dunedin, FL
May 16, 2004
#10
  • May 16, 2004
  • #10
OK, Charged 96, time for an update...! I'd guess all went well and you're out having a blast with a few new found ponies...
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
H
Drivetrain 6R80 to t56 swap
  • Holymoses
  • Apr 25, 2026
Fox 5.0 Mustang Tech Apr 25, 2026
AeroCoupe
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
T
Fox Help Request: Clutch Cable Installation on T5 Swap — I Can’t Find the Mounting Hole
  • TDM389
  • Feb 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 19, 2026
nickyb
