  • SN95 4.6L Mustang Tech
Need ideas on dimpling header while on car
  • Thread starter Thread starter nickthegenius
  • Start date Start date Mar 22, 2004
nickthegenius
1,631
Elwood, IN
Mar 22, 2004
  • Mar 22, 2004
I've been working on installing my headers the past couple days off and on. I've probably spent 5 hours total. Tonight I was going to finish the passenger-side header and mount the starter. Thats where I ran into trouble. One of the primaries is in the way a little bit and I need to dimple the tube. I really, really do not want to remove the header. What I was wondering is if a propane torch would heat it up enough so that I can hammer it a bit and dimple it?
starkie
1,234
South Jersey
Mar 22, 2004
  • Mar 22, 2004
I think that would work.
One other thing you might try is drive it to a local muffler shop. My buddy's 95 GT had a problem with his long tubes and the TKO he installed. The header was hitting the bellhousing. They charged him 35 bucks and clearanced the header for him. Took like 25 minutes and done. Might be worth the trouble if you can't get it.
Starkie
nickthegenius
1,631
Elwood, IN
Mar 22, 2004
  • Mar 22, 2004
I'll try to use the torch first. I'd have to tow it to a shop because I can't start it.
GTblack_00
494
Tampa Bay Area, FL
Mar 22, 2004
  • Mar 22, 2004
yeah, heat it up and use a ball hammer!
nickthegenius
1,631
Elwood, IN
Mar 22, 2004
  • Mar 22, 2004
BTW, here is a shot of whats going on. Its the "nose" of the solenoid that is hitting. It just enough contact that it won't let the starter seat flat on the bell housing. There is no other contact anywhere except in that one spot. You can see my crappy line I marked with a Sharpie. Thats the area I intend on dimpling.
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Mar 22, 2004
  • Mar 22, 2004
what kind of headers are they ??
nickthegenius
1,631
Elwood, IN
Mar 22, 2004
  • Mar 22, 2004
Mac
paver1
330
HELL-The hottest part.
Mar 23, 2004
  • Mar 23, 2004
Not sure you need heat.....Can't you take the starter off and lay a socket on the pipe and bap it with a hammer.....That should give you the clearance you need........If its steel it will work.
nickthegenius
1,631
Elwood, IN
Mar 23, 2004
  • Mar 23, 2004
I like that idea. I'll give that a try before I whip out the torch.
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
Exhaust 1 3/4” Long Tubes on a Fox Body AOD – Easiest route?
  • 5.0 Mike
  • Mar 19, 2025
2K
Fox 5.0 Mustang Tech Mar 21, 2025
5.0 Mike
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
