  • 1994 - 1995 Specific Tech
Need input on mods for a 95' conv.
  • Thread starter Thread starter catpunk
  • Start date Start date Mar 28, 2007
C
catpunk
12
Michigan
Mar 28, 2007
  • Mar 28, 2007
It's my daily driver in the summer. I would'nt mind running premium. I want to put on an intake, cold air kit. I'm also putting on staggered Cobra's on it. It has a newer 2 1/2" exhaust. Also need advice on headers that exit exactly like stock, so I don't have to mod the exhaust. Thanks for your help.
R
red95gtconvert
382
Ponca city, OK
Mar 28, 2007
  • Mar 28, 2007
Since you don't mind running premium I would bump the timing up a bit from the stock 10* btdc, skip the cold air kit and buy a K&N filter and remove the air intake silencer. Any aftermarket shorty header for 94-95 5.0 mustangs will bolt up to the stock exhaust locations so that shouldn't be a problem. I would definately put some better gears in the rear end like some 3.73's or 4.10's, this will help a bunch. Their is a ton of stuff you can do to these cars, have fun.
hollywoodstang
1,095
Mar 28, 2007
  • Mar 28, 2007
First thing you should do on mustangs are gears. Just like the red 95 said for 3.73's or 4.10's. if you gonna put slicks, go for 4:10's, street/strip, go for 3:73's
Header: jet hot FRPP, they are little expensive but 5.0 doesn't like the heat. Then SAVE $ for the heads. The biggest HP gain comes from the heads. get trick or GT-40 alum.
1TallMF
955
Montreal
Mar 28, 2007
  • Mar 28, 2007
Is the mid-pipe still stock with the 4 cats? If so you should swap that out for either a high-flow catted pipe or an o/r (no cats) pipe. Its by far the largest restriction in the exhaust system, and will give the car a much meaner sound. The headers alone won't give you much in terms of seat-of-the-pants feel, but more for looks and a bit of sound, unless of course you go with longtube headers.
And like the other chaps mentioned above, gears are where its at. I daily drive my 'vert with 3.73's in it and I love 'em.
94-302-vert
1,947
NE CT
Mar 28, 2007
  • Mar 28, 2007
Gears first....
Then U/D pulleys are a decent mod (I felt a little power)...
If it is an auto guys rave about the higher stall convertors....
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
Mar 28, 2007
  • Mar 28, 2007
Gears first...Yes.
Then, on a vert.. FULL LENGTH sub frame connectors welded in. This was a "do first" mod years ago, so especially in a 10+ year old car I would say that should be done
RC
STM1965
185
Ontario
Mar 28, 2007
  • Mar 28, 2007
Mods
Like a few others said, gears ( I'm running 373's) If its an auto put in a shift kit, what a huge change it made to mine, BBK headers, and sub-frame connectors. I've done all the above to mine and the car is stiffer, the tranny shifts firm, and when you stand it will hold and shift at about 5k and snap your head back!
JMHO.
C
catpunk
12
Michigan
Mar 29, 2007
  • Mar 29, 2007
Where can I find a Cobra intake? I already checked E-bay. I have all cobra exterior parts and just wanted to finish the look and some more power also. How big of a MAF can I put on? A buddy of mine has 80, would it be too big?
ProKiller
3,064
15
78
PA
Mar 29, 2007
  • Mar 29, 2007
check over at the corral.net classifieds. tons of stuff on there.
check out the FAQ at the top of this forum to see what some guys are running as far as combos. gears are your first stop, not an intake. an 80mm mass air is too big for a stock setup you want to run in my opinion. you don't need a maf right now.
1. gears
2. mid pipe and headers
3. intake
Engine 95 mustang Gt
  • Bett23
  • May 29, 2025
1994 - 1995 Specific Tech May 29, 2025
General karthief
  • Mindseye007
  • Aug 16, 2026
Mindseye007
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
Engine 87 NA - Tune or no Tune needed?
  • R82148V
  • Sep 17, 2025
Fox 5.0 Mustang Tech Sep 17, 2025
R82148V
E
New Member with 91 foxbody
  • EricMac13
  • Jul 22, 2025
  • The Welcome Wagon
The Welcome Wagon Jul 23, 2025
EricMac13
E
