need major help PLEASE
  • Thread starter Thread starter joe23O3
  • Start date Start date Aug 30, 2004
J
joe23O3
  • Aug 30, 2004
hey guys my cars been running like a total dog to the point i cant really even drive it anymore...it has a terrrible and i mean really bad miss to it throughtout just about all the rpm's but extremely bad at full throttle....i replaced almost everything electrical except for the computer... would i be able to run the computer from like a 93 cobra...i have the bigger maf, injectors, and intake already woudl that workout ok? or are there any other parts i could replace to find the problem...i already replaced plugs, wires, cap, rotor, pickup in the distributor, coil, different ignition boxes, injectors, checked the timing numerous times and evne found true tpdc on the balancer to make sure it was right, played with the fuel pressure...its now about 38psi....... any help at all would be greatly appreciated i'm bumming my moms car for school now and need some major help..thanks alot guys.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 30, 2004
  • Aug 30, 2004
Stay away from the Cobra computer.
Whay year car? what are your mods?
Have you replaced the TFI
module?
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.dalidesign.com/hbook/eectest.html for more descriptive help
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
J
joe23O3
  • Sep 1, 2004
the car is a 91 lx with a comp xe roller cam i think the numbers are like 270, 276 and .512 lift., i'm using roush 200 heads which have been fully ported and polished and a trickflow intake, i have a 65 mm. holley throttle body. 24lb. injectors, and c&l meter..... anyways about dumping the codes a good friend of mine has a snapon computer and that wont really even pick anything up and its not throwing any codes. i have replaced the tfi module which made no difference noticeable. thanks alot for your help and anymroe input would really help cuz i'm really lost this time.
J
Js5ohLX
287
Ohio
Sep 1, 2004
  • Sep 1, 2004
How are the plugs and wires? Does it miss at idle, if so did you do a compression test? If it misses at idle, get some sparkplug wire pliers and pull of wires till you find the bad cylinder(s) and go from there.
Help needed - Cranks, no Start
  • sleeping93coupe
  • Nov 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 30, 2025
AeroCoupe
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
  • dan50
  • Jul 18, 2026
dan50
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
L
Engine Need help diagnosing 2 dead cylinders
  • lvgnmz
  • Feb 13, 2025
Fox 5.0 Mustang Tech Feb 13, 2025
Mustang5L5
