  • 1994 - 1995 Specific Tech
need new tranny
  • Thread starter Thread starter autumn_again
  • Start date Start date Dec 1, 2007
autumn_again
356
Hamilton, NJ
Dec 1, 2007
  • Dec 1, 2007
I need a new transmission.
I have the t5 in it now, and the bottom set of gears is all broken away.
I found a t5 thats in a foxbody for 575, what would I need to make that work.
I'm pretty broke, so i can't get a brand new t56 or anything.
recommend maybe sites or something that sell rebuilt t5s, if i could find one specifically for the 94-95 years that would be great.
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Dec 1, 2007
  • Dec 1, 2007
check the classifides over on corral for used ones
if you can turn a wrench and follow directions you can rebuild your own, the T5 isnt difficult at all
d&D performance and astro performance offer rebuild kits/parts
9
95trippleblack
60
Chicago
Dec 1, 2007
  • Dec 1, 2007
Just rebuild yours or find a used/rebuilt one. A fox won't work on a 94/95 without swapping the input shaft and rearing retainer
Give this gay a call
http://www.corral.net/forums/showthread.php?t=792309&highlight=astro
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Dec 1, 2007
  • Dec 1, 2007
A Fox T5 will work in a 94-95, but as 95trippleblack pointed out, you need to swap the input shaft, or use the Fox bellhousing, clutch fork, and possibly pick up a driveshaft spacer to make up the extra length the driveshaft will need to be. The Fox input shaft is 5/8" shorter than the SN95 T5 input shaft.
autumn_again
356
Hamilton, NJ
Dec 1, 2007
  • Dec 1, 2007
nah what is wrong with the tranny is the whole bottom shaft thats just a solid piece with all the gears on it, is that the reverse gear is basically bald.
My father is helping me with this, and hes done this many times, hes an auto tech for 35 years.
every tooth for the reverse gear is basically broken off, i have about 1/4th of the gears I should have.
its also broken on the other set of gears, but i figured that would be decently cheap to replace, compared to buying a new tranny.
everything used for reverse on the tranny is gone, and a couple teeth are chipped on the other gears, from the teeth from reverse flying around.
I was hoping it was a quick fix, but when we ripped apart the tranny, and saw all that, he tried calling up this one person he used to deal with at an old shop, to see if they could hook us up with some prices.
they didn't answer, but I have a feeling, just that main shaft is going to cost alot of money.
9
95trippleblack
60
Chicago
Dec 1, 2007
  • Dec 1, 2007
That bottom shaft is called the cluster shaft its about $100-120. When I blew my t5 the cluster, 3 rd gear and the bearings need for the repair were ~$160 form this guy http://www.corral.net/forums/member.php?u=68276
He also sells rebuilt transmissions. For the a core all they usually care about is the tip of the main shaft and the case
autumn_again
356
Hamilton, NJ
Dec 2, 2007
  • Dec 2, 2007
hm. I gotta see. i was supposed to talk to the people that my dad used to deal with today, but I got caught up with helping out my brother + work.
The things coming into play that are deciding on whether I'm going to go with a rebuilt t5, vs just getting the parts, is the price.
If the price is right, i'll just rebuild the tranny I have now.
but if the price of the parts I'll need for this working correctly, is too close to the price of a rebuilt tranny, I'll just go with the one from astro, the one for 700.
I am starting a job where I'll be working from 11-5 or so, and I have school from 7 to 1045. and then another job working around 6- 8. time is a big thing deciding where i'm going with this tranny.
especially with the fact i need a vehicle to get to work and school daily and this is my only vehicle.
for now i'm driving the car my brother plans on selling in a week or so.
go-stang5.0
2,244
Glenview,Il
Dec 3, 2007
  • Dec 3, 2007
I would look around....t-5 parts are cheap and very common. I think you could rebuild yours nicely for a couple of hundred dollars. Depending on how many gears are chipped and how badly (whether they need to be replaced or not). I'm sure your dad would know tho since he does this for a living.
autumn_again
356
Hamilton, NJ
Dec 5, 2007
  • Dec 5, 2007
called up astro performance today, their tranny is listed as 85-93, but the screen i clicked on said up to 95.
I am hoping that if i just swap the bearing retainer out, that it will work with no problems.
we'll see though.
they are going to call me back i hope soon.'
I called around local junkyards and they are wanting 650 to 800 for the trannys, and the person couldn't get the parts we would need to rebuild mine.
9
95trippleblack
60
Chicago
Dec 5, 2007
#10
  • Dec 5, 2007
  • #10
If you get a rebuild trans you going to want to get the correct input shaft. Swapping the shaft isn't that easy. Their are like 15 bearings and its end play needs to be shimmed correctly.
Also how it the gear on the imput shaft did it get damaged?
call that guy on corral I bet you can get the gears and cluster shaft for a lot less then you think
autumn_again
356
Hamilton, NJ
Dec 6, 2007
#11
  • Dec 6, 2007
  • #11
alright update
ordered new gears instead of buying the whole transmission, because the way it would of worked, it would of cost way more then i am looking to spend, for a tranny that wouldn't be much better then the stock.
bought new bearing and syncros and etc, new input shaft, new bearing retainer. new clutch pressure plate, throwout bearing pilot bearing, resurfacing the old flywheel, replacing main seal.
car should be on the road by next weekend.
Astroperformance.com Stage 3 Gear Kit 450HP (85-93) $469.62
Click to enlarge
Description:
T-5 "World Class" Super Alloy Gear Kit 330 Ft. Lbs. of Torque / 450HP!
Part#:
1352-SAGK
Includes:
1.) Cluster Shaft/Gear
2.) Input Shaft/Maindrive Gear
3.) 1st Mainshaft Gear
4.) 2nd Mainshaft Gear
5.) 3rd Mainshaft Gear
Notes:
This Gear Kit was found in all of the Ford Motorsports "Z-Spec" T-5's. This Gear Kit will only work behind a 1985-93 Mustang 5.0L Bellhousing. The Input Shaft used in this Kit is a "Needle Bearing" Design, not "Tapered". This Kit will convert your "Heavy Duty" or "High Alloy" T-5 Transmission from a 3.35 1st Gear Ratio, to a 2.95 1st Gear Ratio! If you reuse your Factory/OEM 5th Gear Kit (5th M/S = 27T & 5th C/S = 59T), your Final Overdrive will be even more Fuel Efficient! Your Final Overdrive Ratio will be a .61%, instead of the Factory/OEM .68%!
they are the gears i bought.
i bought the king cobra clutch also.
autumn_again
356
Hamilton, NJ
Dec 11, 2007
#12
  • Dec 11, 2007
  • #12
got my gears, and clutch, bearing retainer didnt show up.
he was saying something about he might not get it till monday, but we wanted everything shipped the same time, just because it doesn't do us much good missing a part that we need to replace.
I'll have to call him up, maybe he did ship it and UPS just forgot to grab that box.
the clutch box was heavier then the gear box, didn't expect that at all,but i guess with the pressure plate it adds up.
stuff i still need for my car:
fog light bulb for one side
rear main seal
tranny fluid.
and then i should be good.
New Member with a 1992
  • Clutchfork
  • Oct 18, 2025
  • The Welcome Wagon
The Welcome Wagon Oct 19, 2025
Clutchfork
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
T
Greetings from a guy who needs help with a foxbody.
  • thefonztm
  • Mar 21, 2026
  • The Welcome Wagon
The Welcome Wagon Mar 22, 2026
I
2000 GT Mustang - Transmission Cooler to Radiator o-rings
  • Iwarrior
  • Oct 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Oct 4, 2025
Iwarrior
I
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
