need part number trick flow
  • Thread starter Thread starter noslow1986
  • Start date Start date Feb 25, 2007
N
noslow1986
274
oswego Il
Feb 25, 2007
  • Feb 25, 2007
whats the part number for trick flow heads i want some decent but not a big head anyone know the part number summit uses. what other parts will i need to put this together
P
PJB
131
Rotterdam, NY
Feb 25, 2007
  • Feb 25, 2007
TFS-51400004 Twisted Wedge Heads, Assembled
Thats the part number of the heads used in the top end package:
http://cgi.ebay.com/ebaymotors/TRIC...ryZ33617QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
That link lists all the individual part numbers for the Trick Flow kit pieces.
87_stang
131
Tonganoxie, KS
Feb 25, 2007
  • Feb 25, 2007
http://store.summitracing.com/partdetail.asp?part=TFS-K514-350-370&autoview=sku
Those are probably the heads you are thinking of but all I cound find was the complete engine kits for some reason and not just the heads but that will give you an idea on the other things you will need to go with them. If you cant find the heads only just give them a call and ask for the part number. I believe the # is 800-230-3030
N
noslow1986
274
oswego Il
Feb 26, 2007
  • Feb 26, 2007
which one
whats the different in valve 1.47 or 1.46 valve spring. im thinking 61 cc 2.02/1.60 at 540 lift this is the bolt on trick flow head right they have so many i confussed i dont need the kit cause i already have the manifold. and i dont need anything big. i want something better then e7 heads and how does trick flow compared to edelbrock heads
Busted07
I need my gorilla to be about an inch longer.
Nov 15, 2005
  • Feb 26, 2007
www.trickflow.com
They have a tech line just for TFS.. they can answer any questions you have.
Trick Flow Series R to Box R Upper Intake Road Block
  • Habu135
  • Mar 31, 2026
  • 2 3 4
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
Habu135
Melling M-10687 Green Spring
  • AeroCoupe
  • Aug 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 23, 2026
AeroCoupe
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
SOLD Trick Flow Box R Series Upper Intake w/90 mm Inlet
  • Habu135
  • Apr 30, 2026
  • Engine and Power Adder
Engine and Power Adder Aug 19, 2026
Habu135
