Need Remote Tank Power Steering Pump Advise
seaya67
Need help on older resto mod but know you guys are the ones that can help due to my engine setup. Have a 68 Restomod that has 5.0L (347 Turbo) engine that has a March accessory brackets and pulleys. I have a stock 5.0L power steering installed (same as all foxbodies), that is ok but the plastic return nipple on the bottom is way to close the exhaust. Need a smaller pump or remote tank that will bolt up in essentially stock location. I found a remote pump, KRC Kit, however it has a different bracket an not confident it will fit with AC and in stock location/alignment. Any help would be appreciated.....
FYI...Car has a mustang II coil over system as well....so low pressure needed.
Anybody?
