  • SN95 4.6L Mustang Tech
NEED SERIOUS OBDII HELP...
  • Thread starter Thread starter overpower
  • Start date Start date May 8, 2009
First Prev 2 of 2
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
May 22, 2009
#21
  • May 22, 2009
  • #21
overpower said:
I've done that before. Obviously when I load the stock tune, It sets the MIL light for O2 Sensors and Heater. They are there and working, but the Long Tubes and Catback set it off.
What codes do you get exactly, when you load the stock tune back on? The longtubes and catback shouldn't have anything to do with a MIL, but I could see it throwing a code for the downstream O2 sensors if you have no cats, or if the downstream O2 sensors are somehow turned off in the tune. Knowing the codes with the stock tune is really the key here to finding a solution to the issues you're experiencing. You may have a hard fault of some sort, which the tune is changing parameters and ignoring a fault condition.
BlownFiveLiter
18
108
Chicagoland
May 22, 2009
#22
  • May 22, 2009
  • #22
I copied this thread over to 05-09 GT Tech, being that it's an S197 we're discussing. I'm leaving this one intact, so we can have more exposure and suggestions coming in.
Here's a link to the copied thread in 05-09 GT Tech: http://forums.stangnet.com/786131-need-serious-obdii-help.html
O
overpower
29
#23
  • May 22, 2009
  • #23
All tunes I have tried have the O2 sensors turned on. With the stock tune, I get the following codes: P0155 and P0161. I know they relate to the O2 sensors and Circuits. This is only with the stock tune. The JDM and Bama tunes were verified (O2's On), but they dont throw any codes. Just doesn't complete.
hotcobra03
poteet,tx
May 22, 2009
#24
  • May 22, 2009
  • #24
you say you have long tubes,,,i had a problem with mine...we added to the harness the old way with adding wire....than we used new o2`s with the longer harness,,and now no codes...
when you install the stock tune,,with key on engine off do the o2 heaters come on? feel o2 it should get very hot with just key on
O
overpower
29
#25
  • May 29, 2009
  • #25
JDM Fixed it !! - All, listen to this. I brought the car to Jim at JDM Engineering. He verified that all of the sensors were working, cats are there, etc.. They were unsure what was causing the issue, but did say that the JBA headers were "Very" Long. He modified the tune to increase the monitor temp of the rear O2 sensor. We loaded the tune and he hooked the car up to more monitoring gear. We ran the car for about an hour (not moving), but the same 3 monitors still said inc. He suggested that I put some miles on the car and maybe stop back to check again. I left and while I was driving, hooked up my OBD Scanner. After 3 miles, the O2 Monitor and O2 Heater Monitor went green (complete). I couldn't believe it. I drove straight to the NJ State Inspection Center. The Inspector Immediately opened the hood for a look, but went on with the inspection. GOT MY STICKER !! It Passed !! I have to say if you guys need a real pro and expert in stangs, go to JDM. They are unbelievable and great guys to work with. Thanks to all for your suggestions !! JDM is the BEST ...
squeak93
2,351
417
164
Joplin, Missouri
May 29, 2009
#26
  • May 29, 2009
  • #26
Glad to see you got it fixed.
MaxedGT
304
Surrey BC Canada
May 30, 2009
#27
  • May 30, 2009
  • #27
Jim's a smart guy!
First Prev 2 of 2
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
  • Gulftown980x
  • Jul 29, 2026
squeak93
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
G
2016 GT, Cold Air/Tune Trouble (overheating) . Advice/Help Please!
  • GLStang
  • Sep 6, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Sep 6, 2025
J
'96 Cobra: A/C gets weak and engine misfires under load when warm
  • jruhnke
  • Oct 22, 2025
  • SVT Tech Forum
SVT Tech Forum Nov 20, 2025
nickyb
