need short belt size
cj99
74
Tonopah,AZ
Hello , I have a 86 5.0 that i have removed A/C ,& Smog pump
now i only have water pump, ALT , powerstreeing pump
what belt size do i need to make this work
thanks
P.S. i am restoring this car. for a track car only
:lol:
short belts
you did the same, so you still have powersteering and alt on , no smog or A/C
correct. did you have to move you idler ?p.s.
what the other guy said.. stickeys what is that:rlaugh:
do you have pics of it ?
thanks
GreatWhite said:
told ya around 70.5" :nice:
ya ya . the other guy said he had the same mod and that worked
anyway why do you say 70.5 ?? i ask because as you know every inch make a big diff./ so i dont want to go to small. 73.5 the idler pulls it tight but it hits the belt oin over the water pump
i am thinking 71.5 but if you are sayin you know. then i will get the 70.5 .. i know these belts stretch alot after running them
:hail2:
You simply have to either measure or trial and error it. For example, my car with the 3g alt uses a 74.5" belt that fits perfectly. The 86 GT will have a different size waterpump pulley than 87+ so that will throw it off right there. Somewhere between 70-75 inches will be what you need, you'll have to figure it out for the exact measurement.
