  • SN95 4.6L Mustang Tech
need some advice
  • Thread starter Thread starter ninjastang125
  • Start date Start date Jan 5, 2009
First Prev 2 of 2
N
ninjastang125
591
maryland
Jan 7, 2009
#21
  • Jan 7, 2009
  • #21
i have been doing some research and has anyone heard anything about a company called tork tech? they have kits to put m112 supercharger ( one similar to the 03-04 cobra) onto 2v engines. has anyone here heard about them or deal with them before? im going to upgrade suspension and tires and most likely get this kit and run 7 or 8 lbs of boost on my stock bottom end for pinks then after that get all forged. what e.t should i run with this set up?
evil281
276
Arizona
Jan 7, 2009
#22
  • Jan 7, 2009
  • #22
use the search options theres a ton of threads on tork teck kit, let us know what u do!
squeak93
2,348
417
164
Joplin, Missouri
Jan 8, 2009
#23
  • Jan 8, 2009
  • #23
Looks like a great deal and can make a good amount of power for u. But u will for sure need the susp and tires to make it work for u. Good luck and keep us posted.
02nightmaregt
To hell with your Mustang, I want to see your HOG!
Jul 1, 2007
513
Southern Indiana
Jan 8, 2009
#24
  • Jan 8, 2009
  • #24
ninjastang125 said:
thanks for all the help im going to upgrade my suspension for better launches my problem is i accelerate quickly but its seems as my power dies off at the top end what could i do about this? i would like to fet as good as a time as possible not just 12.99 i just need that time to be able to race my car there. im not a big fan of nitrous and really dont want to use it. what lift cams with stock heads should i buy
Why are you against Nitrous? Boost is the same thing
squeak93 said:
I have found 5500 is a good spot for a stock car with o/r x and weld in mufflers. (4.30 gears to). I had about 150 runs in that car and found that was the best (Btw I started my shift at 5500 so it was more like 5650ish.)
Don't run to red line. Bad idea. U can buy a plenum and t/b and get a few more rpms but not red line still.
Thats where my shift light is set When i installed my TB/plenum it helped it to pull all the way to redline
QUOTE]
BlownStangGT
REPEAT
3,860
Lancaster, PA
Jan 9, 2009
#25
  • Jan 9, 2009
  • #25
Everyone has some great suggestions but lets look at this. You want to run 12.99 to get into pinks all out. When you are there, you will get probably 2 "test" or time trail runs in. From all the shows I watched, after the 2 time trails they pick the field. In all the episodes I have watched I do not think I have ever seem them pick a 12 second 16 car field to run for the 10k cash. Most of the times its 10 or 9 second cars. Not saying they wont, but that seems to be the trend. SOOOOO....are you building your car just for that? Or to have a 12 second car? If you are building it for a 12 second car then thats that, but if your building it JUST for the pinks all out, its pointless in my opinion. I would rather build the car for my fun and enjoyment. Do it right the first time, or else you wil be going back and back agian and agian and agian to fix things
First Prev 2 of 2
Need help ordering a oil cooler and filter relocation kit but don't know what I need
  • Aiden Brown
  • Aug 22, 2026
SN95 4.6L Mustang Tech Sep 14, 2026
squeak93
  • Mindseye007
  • Aug 16, 2026
Mindseye007
347 with Vortech V2 and Holley quick fuel, AFR Renegades a tremec tko 600 advice for newbie pls
  • Schargedfox
  • Jul 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 3, 2026
Schargedfox
N
Fox Street Suspension Build Advice
  • NYFox
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 28, 2026
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
