  • 1994 - 1995 Specific Tech
Need some cam help
  • Thread starter Thread starter deadlast
  • Start date Start date Sep 11, 2006
deadlast
495
Belmont, MA
Sep 11, 2006
  • Sep 11, 2006
ok so i have a pretty mild setup. tfs street intake, 75mm bbk tb, o/r h pipe, magnaflow catback, u/d's, ac and smog delete, and 3.73s. seeing as there is not alot of cheaper stuff to buy for my engine anymore, a camshaft is looking to be good for me right now. anyway, i did some research on possible cams, and i have gotten suggestions for either an F303, Crane 2031, Steeda #19, or a comp cams XE27HR. i dont have heads which is gonna hurt the combo, but which cam will provide the most hp w/o drivablity loss for my setup?
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Sep 11, 2006
  • Sep 11, 2006
If you're gonna go to all the trouble to change the cam
and
that is no little job
I'd just have to ask you .......... why do it and not upgrade the heads at the same time
If you did just the cam ...... you won't pick up much of a gain
also ... if you did just the cam ... the one that would work with your E7's would most likely not be the best choice for better heads in the future
No way I'd tear all that stuff apart ...... twice
That last part you brought up about drivability ............
Hey ... if you're really considering making any kind of power
Chances are ... you're gonna have to deal with it ...some how
after all
why should you be any different than all the rest of us
Focus on drivability
and
you'll most likely give up some gain
Seriously ... Just start saving up and do the heads & cam together.
Might consider things like
larger fuel pump
larger inj's
a way to tune if DRIVABILITY rears its ugly head
Grady
deadlast
495
Belmont, MA
Sep 11, 2006
  • Sep 11, 2006
yea thats what i was worried about... damn.
T
tjh566
608
Northern Va
Sep 11, 2006
  • Sep 11, 2006
I put the steeda #19 in, I lost some low end but it really kicks it in the upper end now, havent really got on it too much as i am makin sure everything is together well, just got it back together saturday, so far she runs great, idle is fine and drives great
Edit: And yes it is a big project, gotta take alot of **** off and even then the cam barley clears coming out, mine hit the sheetmetal out front and had to go sideways just a little to get her out
Brozz
11
Rhode Island
Sep 14, 2006
  • Sep 14, 2006
I added a B303 to my basically stock engine and it made a world of difference. Yea, the cam is mild, but it added a ton of low end torque and some sweet power on the top end as well.
Bigger is not always better, and I highly recommend a Motorsport cam for your Pony.
N
Engine 1994 Mustang GT AODE puzzling issues
  • noah5slow
  • Oct 22, 2022
2K
1994 - 1995 Specific Tech Oct 29, 2022
noah5slow
N
Need Some Help. Cam Question
  • 2/75TH RANGER
  • Dec 23, 2017
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 31, 2017
revhead347
Fox Aod W/ Crane 444225 Cam - Need Help Choosing Torque Converter!!
  • MLee23
  • Jun 17, 2015
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 18, 2015
mikestang63
T
Fox No Boost And Stumped
  • TWEECD
  • Aug 12, 2017
  • 2 3 4
13K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 31, 2017
TWEECD
T
Need Help!!! Motor Won't Stop Burning Oil!!!
  • Broken03GT
  • May 19, 2015
  • SN95 4.6L Mustang Tech
3K
SN95 4.6L Mustang Tech May 20, 2015
COramprat
